hmmm maybe it's a newbie question i don't know i tried looking
okay the diff between the 03 and 04 is that 04 has the returnless fuel thingy right? and since rrm turbo are only for 02-03 and only two ppl i can remember tried to turbo their 04 but had some issue, if by any chance if i found a 03 engine which i have at a junkyard could i put that in the 04 and get rrm turbo?? :lol:
i think rob fixed that issue, if not then i'm it will be shortly... talk to rob he can help ya
that would be quite a lot of money... it'd be cheaper to go custom turbo
You would have to swap out the engine (and probably the ECU and harness) and the entire fuel system. It would probably be cheaper to get the RRM kit (minus the fuel system) and then have a shop solve the fuel delivery.
just give the rrm guys a lil time to adapt the trubo kit.. then boost away.
Call RRM, don't post...
And an engine swap will be far too expensive. Just work around any fuel issues you have. Work smarter, not harder. |
| All times are GMT -7. The time now is 01:12 PM. |
