Can't open trunk with key
So, I tried to open my trunk with the key, and it doesn't work. When I put the key in, it seems like I have the incorrect key. The cable release from the driver's side works fine. Has anyone else encountered this? I've had my Lancer for about 4 years now.
I've had the same problem with my 04 OZ (haha same color too!) Anyways I took it to the dealer recently and they "lubed" it for free. Works perfectly now. Might want to try swinging by your :mitsu: dealership and see if they will do the same.
Any problems with your moonroof? They also lubed that and fixed it... Just curious if you have had that problem too? |
Thanks! I'll try stopping by the dealership.
The only issue I had with the moonroof is that it wouldn't vent until I opened the roof and closed it. Weirdest thing....a month ago.....and hadn't had a problem otherwise. |
Originally Posted by LancerMarita
(Post 6086082)
The only issue I had with the moonroof is that it wouldn't vent until I opened the roof and closed it. Weirdest thing....a month ago.....and hadn't had a problem otherwise. It' fixed now but just frustrating because I was out of town with a car full of people when it decided to break haha... |
my stupid moon roof goes wacky sometimes too
i mean i own an 03 but sometimes when i try to vent it, it gets like jammed or something and i have to open and close it blah blah blah after a while it seems to work but this only happens sometimes lol |
What cause the trunk not opening right?
My trunk key used to stick alot when I first got it, I just lubed it up and put it in everyday... ;) haha
When they started putting trunk release buttons in cars, people stopped using the key. Locks freeze up when never used. I had the same thing. WD40 your key and lock and keep trying it. Eventually it will work.
The trunk uses a different key i'm pretty sure. Mine also does this and i remember when i got it, it never worked. The key we have is probably a valet key or something.
---Edit--- lol nevermind i have no idea what im talking about...it probably does lock/freeze up. |
| All times are GMT -7. The time now is 04:11 PM. |
