rrm piggyback AT help
i bought a piggyback off a member on EvoM (TAJ) and he included the install instructions but I'm having some trouble..in the instructions it says to connect the piggyback vacuum line but this particular piggyback doesn't have a vacuum line opening..he says he had it installed on his lancer..anyone else have a piggyback like this on their 02?
http://i9.photobucket.com/albums/a64...3/IMG_6099.jpg |
The vaccum line is for version 1 of the piggy back (older). Version 2 does not have a vaccum line. I'm guessing you have version 2 because there is not vaccum line. Make sure you take your time when you hook it up. I believe you use the wires with the black dashes on them (if you have dashes).
Jake |
***Please edit this post to be in compliance with the new FS rules or else it will be deleted, thanks***
https://www.evolutionm.net/forums/sa...uncements.html
Originally Posted by Berto05
(Post 9070265)
I was only seeking help on here..it's not a FS thread..
Odd, i didnt catch any sale vibe on this thread. Anyway, you seem to have a version 2 piggy like another user stated there is no vacuum line on it so just do the wiring.
(Post 9082064)
Do you still need help hooking it up? |
here's the color diagram for how the wires are connected for the RA
https://www.evolutionm.net/forums/04...tructions.html i'm not sure if the color wires are the same but it gives you an idea of how it is supposed to be connected |
