-   Lancer General (https://www.evolutionm.net/forums/lancer-general-9/)
-   -   Car won't start/Front ECU noise (https://www.evolutionm.net/forums/lancer-general/570926-car-wont-start-front-ecu-noise.html)
RallyLancer Aug 22, 2011 07:53 AM
Front ECU started making noise, now car won't start.....nothing. ECU will continually make noise without keys in ignition. Think if I replace Front ECU car will start? I've read the other threads about the Front ECU but no mention of the car not starting....
WangMan Aug 22, 2011 10:33 AM
The electronic control unit is making noise? Sounds unlikely... :confused:
Green_Bandit Aug 22, 2011 05:16 PM
I know what sound he's talking about. Its a distinct clicking noise. It makes the same sound when you disconnect reconnect your battery or flash your ECU.
Battery? Because if there is minimal charge there wont be enough power to turn the car but that little ounce of juice will keep powering the ECU.
Vivid Racing Aug 22, 2011 05:30 PM
The clicking sound is probably relays. The "front ECU" controls most of the lighting, which means relays are needed.
OP: Has the car gotten wet recently?
Jsapp Jan 11, 2013 12:06 PM
I had this same issue. I took my cables off my battery the day before to clean off corrosion and when I put them back on my car ran fine for a day then did this. Ecu clicked when car was off and had zero power when trying to turn over. Problem ended up being that my negative battery cable wasn't all the way down on the battery and didn't get tightened all the way. Make sure to check battery connections! I was about to buy a new ecu! I'm sure your problem is already solved but when I did my research this topic didn't have the answer so I wanted to post it for anybody with the same problem.
Evo8ateyourv8 Jan 13, 2014 06:38 PM
DidYou ever figure it out? My Evo is doing the same thing.
marcoEVO9 Jan 25, 2014 06:53 PM
try checking your grounds.
Evo8: does it do it all the time or during certain conditions?
02-Lancer-Es Jan 26, 2014 09:47 PM
The clicking is the idle speed motor ..........
Evo8ateyourv8 Jan 27, 2014 03:40 PM
All the time. I ordered a new starter because that what everyone on my other evo forum said so we'll see
carwontstart Mar 7, 2015 07:51 AM
ecu noise
Call me mad but I have an ecu that makes a singing noise, a constant sound like a soft beeeeeeeeeep. My car will not start. The starter engine turns, the red light on the dash blinks faster when I turn the key, even before starting. I smell gaz from the exhaust pipe. Time for a new ECU? Does that need tuning to the car by an expert? I heard this from someone and it seems to cost a LOT!
