any more preventative maintence needed?
I got a 03 OZ rally with 48k with a Auto trans.
I was just wondering if i need to do anything else in terms of preventative maintence or things i should look at that might be given out and etc.
GF has own the car since new. And well oil changes were always done at 3-5k. its been thru 2 brake jobs by other people.
at 30k its got new tires, i put in new sway bar bushings and endlinks on both sides as they were broken and worn out. i did air filter and spark plugs. i performed a BG induction service since i had the stuff for free. cleaned out the throttle body, did its 3rd brake job with new rotors and brake flush.
recently at 48k, i did the trans drain and fill because fluid started to go brown and i know it was late since it was a 30k thing. the belts look good do i didn't replace those. I dont know where the fuel filter is nor do i know what the life of that is.
i'm going to do another, brake job near 50k ( its 4th one, yea i know she rides on the brakes and etc). I was wondering if there is anything else i should look into that might be worned down from wear and tear or any trouble spots that mitsi has failed at.
the car seems to have a VERY small oil leak, its seeping thru the timing chain cover that i haven't inspected it yet but its not serious as no drips on the floor.
any thoughts on this, i don't have a FSM or anything. i've just done everything according the my car knowledge.
thanks guys.
thanks guys.
