Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
fogs
Old Jan 5, 2011 | 11:51 PM
AJ18's Avatar
fogs
ok so basically i am installing 99 galant fogs on my 2010 lancer de. i have to make the connectors and switch from scratch. the bulbs used are 893 12.8v and 38w. so my question is: 1. what gauge wire do i use? and 2. how do i even wire this thing?
Old Jan 5, 2011 | 11:58 PM
02-Lancer-Es's Avatar
Just pick up a Hid relay harness that way they are powered correctly without any chance of melting wires . Change out the plug , instead of being to a ballast which is a 9006 bulb convert to plug to a 880/H11 plug . After that use the female harness positive as the trigger for a button inside the car with it switched on and off by getting a tap and tapping into your low beam or parking lamps . For the negative on the trigger just ground it out somewhere .
GL !
If needed i can try and make a harness like this !
Old Jan 6, 2011 | 01:22 AM
Evo10HKS's Avatar
why not just get OEM type fogs off ebay? they run relatively cheap, with wiring
Old Jan 6, 2011 | 09:27 AM
AJ18's Avatar
thank you, and because i found them at the junkyard which is a lot cheaper than ebay and its always good to learn something new.
Old Jan 7, 2011 | 05:47 PM
AJ18's Avatar
ok so installed the lights the only problem i have is trying to mount the switch. i want to mount it next to my steering wheel where my asc switch is but i cant figure out how to remove the switch plate. anyone have any ideas?
Old Jan 7, 2011 | 05:50 PM
They usually pop out with a little force or get a small.flat head and from the inside pry it a bit .
Pipefish
Outlander Sport
28
Jul 21, 2025 03:57 AM
1BADSS/SC
Jan 27, 2011 07:04 AM
redralliart04
04-06 Lancer Ralliart How To Requests / Questions / Tips
95
Sep 20, 2008 12:04 AM
marshall15
Aug 21, 2006 09:58 PM
ThEHiTMaN
Nov 9, 2003 11:15 PM
