Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
shifting without clutch?
Old May 24, 2011 | 07:35 AM
tcon89's Avatar
i got a 2011 gts 5 spd. ive been trying to increase my skills with different shifting techniques such as double clutching and heel toe shifting. i want to learn how to shift without using the cluth but this can be difficult due to to fear or tranny damage. i tried it once and when i tried shifting from 4 to 3 w.o the clutch the shifter just wouldnt go into gear. no grinding sound or vibrations in the shifter, it simply just wouldnt go in. is this normal? i always thought that if u didnt match the rpms percfectly when trying this that gears would deff grind? thanks for replies in advance.
Old May 24, 2011 | 07:40 AM
boostedtres's Avatar
please do not shift without using the clutch. or if you do, buy an auto. yes, it can be done. yes I have done it numerous times (not in my evo tho). its not faster and unless your a pro rally type driver there really is no need for it.
the same can be said for double clutching while driving. with the invent of synchros there really is no need to do so. again, there are always exceptions, but for a normal driver, esp on the street, no need.
heal/toe shifting, yes work on that. increases fun of driving the car and smoothing braking/gear changes. also helps weight transfer and engine braking in regards to corners. can go into more detail, but main thing is shifting w/o the clutch for the average driver on the street is just asking for trouble.
Old May 24, 2011 | 07:45 AM
meltdown's Avatar
You sure you don't mean no lift shifting, not shifting without the clutch? Where you push in the clutch and shift while you are still WOT?
Old May 24, 2011 | 07:54 AM
yitzac1990's Avatar
i actually was forced to not use the clutch a couple times, once when I blew my slave cylinder in my friends neighborhood, and another time when I had a broken left ankle, but needed to get myself places. luckily I had already practiced when my car and ankle were fine, so I knew what I was doing for the most part. when you downshift without the clutch, remember you have to take it out of gear, then rev up a bit, and then put it into the lower gear. I know what you are talking about with the no grinding, my lancer did that sometimes as well, and grinded sometimes too. idk why, just did it.....
as said, its not really the best for your tranny, but then again, if you get into a situation where you need to shift without the clutch, its good to know how!
Old May 25, 2011 | 08:13 AM
tcon89's Avatar
I dont shift w.o the clutch regulary, actually i only did it in one situation just to learn how to do it. How bad is it for the tranny and how long would it take until damage was done? Now im worried that my synchros are now unecessaryly worn out due to this.
Old May 25, 2011 | 08:59 AM
yitzac1990's Avatar
all depends on how well the tranny is built and how godo the parts are, but no matter what it can only really cause harm. dont know exactly how many times you need to be shifting without the clutch or w/e, but if you shift without it "correctly" and smoothly every time, its different then slamming it into the gear and grinding on your way in every time... its better to use the clutch all the time, unless in an emergency like I had to...
Old May 25, 2011 | 03:02 PM
CamShaft's Avatar
You wont wear the syncros shifting without a clutch. You will wear the teeth on sliding collars on the main shaft. Just dont do it.
Old May 26, 2011 | 01:06 PM
tcon89's Avatar
Ok so do you guys think that any damage has been done to any internals of my tranny from just one situation? Im just super paranoid about my baby. Lol
Old May 28, 2011 | 09:31 AM
CamShaft's Avatar
yeah I am sure you have worn a little off the teeth of the shift collars. Unless you have problems shifting right now then I doubt you did enough harm.
Old Jun 27, 2011 | 02:35 PM
sam8989's Avatar
ur car is probably ok but avoid shifting without clutch ever again
Old Sep 18, 2012 | 04:36 PM
JDMEVOLEX's Avatar
What if you shift without the clutch during low Rpms. For example stop sign to stop sign on a city block.
Old Sep 18, 2012 | 05:10 PM
ambystom01's Avatar
Why the hell wouldn't you just use the clutch? Are you racing for pink slips or something?
weeeeeeeeee
May 17, 2016 01:21 PM
Kreeker
Feb 5, 2016 01:52 PM
raywong
40
Sep 16, 2015 03:49 PM
Harumsevo
Jul 30, 2013 05:19 PM
tsi1991awd
Feb 2, 2010 07:34 PM
