Need a acc link in fuse box.
Hi, I have 2004 lancer ES and would like to know where in the engine fuse box I can find a acc link for when the car starts. I am installing a pair of drl and need a acc link.
I check all the fuse in the fuse box and all have power when engine is off and key is out.
they don't have power, they will all have voltage yes because they are connected to the battery, to actually power the system in question, it requires a ground through relays/switching etc. in other words no ground, no current flow
that being said, most of the stuff in the fuse box under the hood, is lighting and engine sensors, and accessories...PM me a reminder and i'll have a look through the wiring diagrams when i get home and find you something
DRL and fuse box pics
Hi, did you find anything, here is picture of the DRL controller. I will get a better one of the fuse boxes. I found a fuse inside the car on the driver side (mark ignition) I may use that one but I will have to get through the fire wall. It would be easier if I can find one in the engine.
StreakGSX
Dec 10, 2018 02:56 PM
Darkn3s
Mar 6, 2011 11:05 AM
