My highbeam doesn't work!
Hi,
Does anyone know why my highbeam doesn't light up? I pullback on the knob and no light comes on. My lowbeam works fine. What's weird was that when I put the knob on the middle position and pullback on the knob, the lowbeam lights up. Any help would be nice... |
Change your light bulbs with new ones.
FYI your car uses 9007 bulbs. |
check your fuses as well, if its both bulbs odds are its either a fuse or the switch actually in the steering column is shot.
bulbs
FYI your car uses 9007 bulbs. plus are both not working or just driver/passenger side? |
Any recommendation on what 9007 bulbs are recommended? I bought the Silvania 9007 at autozone so I guess those are wrong bulbs?
no i use those no problem
Hmmm, what does it a dual filament look like? Mine looks just like a normal bulb. Oh yah, where in the fusebox do you check?
umm the lower left cubby if u pull it out i think the fuse descriptions is printed behind it.if not i'll pull up the diagram for u at work and post it. and all headlights should be dual filatment i think not sure.
Welcome
2002 Mitsubishi lancer es
I'm having the same issue I had switched to LED lights and had been working fine hi and low. Just recently my high beams will not turn on. High beam fuses checked they was fine still replaced and nothing. Guessing it's the steering column switch since there is no headlight relay fuse ugh 😩.
| All times are GMT -7. The time now is 09:47 AM. |
