Center Console
Does anyone know exactly howto take the center console apart so that the shift pattern peice can be removed?
open the arm rest then pull up on the cup holders. everything should pull right out. there are two screws holding in the trim around the shifter. as far as taking off the shifter idk.
Originally Posted by spydy98
(Post 5233708)
It should be the same for both. Not 100% sure havent gotten into a CVT yet so idk. the only difference should be how the shifter comes off. if some one lives close by in new york with a cvt i would be glad to see how it comes apart take me only 10 minutes
how do u get to those screws?
Originally Posted by Blacksheepdj
(Post 5236100)
Is that for MT, CVT, or both?
ill try to take a few pics two show u tomorrow
first your gonna have to remove your shifter. then pull up on the cup holders
http://i141.photobucket.com/albums/r...310081026a.jpg then you will see two screws http://i141.photobucket.com/albums/r...310081026b.jpg take them out and lift of and the trim around shifter http://i141.photobucket.com/albums/r...0310081027.jpg and away you go |
how bout behind the climate control? i think i saw a pic that ur gonna have to come around the "carbon fiber" at the top of it.
i wanna get to behind the aux. kinda want to install an soundgate aux3.. any one have the diagram or manual to take it all apart? just like u got there. it looks like u have an aux input wire coming to that lil phone holder thing. |
check your PM.
