Headlights dimming/flickering when 2000rpm's or less
So basically I tried to hook up a 900w amp the other day and blew the alternator... I guess. Car shut off and I had to get it to oreillys to get a new battery I figured mine was 4 years old. Still didn't start up without a jump and guy said I blew a diode on the alternator . So I did the big 3 , replaced alternator battery and now it starts and runs but my headlights are flickering when my rpms are low , like idling. Runs good otherwise but I don't want to hook up the amp til this is fixed and I know the alternator is good
Originally Posted by Dfannin6640
(Post 11135357)
what i failed to mention is that i tightened the belt after succesfully installing the new alternator and dropped my ratchet which touched the alternator (i know im stupid for not disconnecting the - terminal) and some sparks flew but it still started. Im sure i did the big 3 properly but i removed the old + wire as it was pretty corroded and nasty. I figure 0 gauge should be just fine for + to alternator. all fuses are good to go also. i did check the voltage at oreillys once i replaced battery and alternator (after ratchet incident) and found that battery was OK but alternator at idle was low output <30 amps. the headlights are fine when revved to 2500-3000 rpms but once it drops down below 1500-2500 the lights go dim. Could it be the voltage regulator in the alternator? If so it looks like its inside the alternator and tough to get to but i'm wondering if i should just go ahead and try and replace the alternator again.
the alternator said brand new
(Post 11136698)
| All times are GMT -7. The time now is 01:57 PM. |
