YL-388 relay fog light wiring harness relay conversion
G'day
If you pickup an eBay kit to setup fog lights for your car , there's a good chance the wiring harness will have the YL-388 relay in it. The YL-388 is a pest at the best of times , simply cos it's frustrating to find a replacement for and when you do , the replacement relay is usually not cheap. So , the solution is to replace the socket with a standard relay base and therefore make your life so much easier to find and purchase replacement relay down the track. I have documented the process here for you all http://imgur.com/a/tlTjA2J This makes zero difference if the wiring harness is for a Mitsubishi or Toyota or Kia or whatever. This will work and save you time , money and frustration down the track. Enjoy |
