Kartboy shifter linkage bushings install
1 Attachment(s)
OK, this is the install for the Kartboy shifter linkage bushings.
http://www.allwheelengineering.com/b..._class=KB-E006 |
1 Attachment(s)
These are the two shifter linkages. One is facing the camera, the other is at a 90 degree angle to it.
2 Attachment(s)
First, remove the cotter pin holding everything down. Save it and the washer for later. Gently push the bushing out, leaving you with what you see.
1 Attachment(s)
Now push the bushings in and put them on the linkage. It will look like the picture. Put the washer back on and re-insert the pin.
NOTE: you may want to leave this linkage off for easier access to the other. It makes life easier. :D |
1 Attachment(s)
Next, do the exact same for the bottom linkage. The bushing is a little harder to push out, but no problem.
1 Attachment(s)
Now, grab your Kartboy shifter (you bought that too, right? :lol: ), and feel how TIGHT your shifter is!
Discuss thread here
