Mirage / Lancer Compatibility?
yeah at this point i'm confident the flywheels and clutches match up, id just now like to know if a mirage lsd will work on the lancer. do any of you know a place to get a mirage clutch that will handle at least 250 ft/lbs, for a decent price?
clutchmasters.
EDIT: i measured the OEM fly and got a dead 11in. however, it does utilize the 7 bolt pattern. i'm really tired and don't feel up for counting teeth yet.
hey i was curious to see if the flywheels were the same as well. i found that the fidanza for our car is far too light for street use, and a couple vendors have told me about the 1.8 flywheels made by ACT. it seems that there might be a slight discrepency in the diameter between the 1.8 and 2.0. anyone found anything else out yet??
i have also thoght about this, i believe it would fit, when i put my stage 2 clutch in i used the 1.8 mirage aligment tool, maybe somebody can get a deal with a company for a test fit , so that way they can also market it for lancers they would be beneffiting from it.
the CK5A(1.8L) and CS6A(2.0L) do have the same part number for the flywheel. MD749708
the TOB also match between the mirage and the 04+ lancer. this is because in the 02-03 lancer, the TOB and clutch release fork were a single assembly. in the 04+, it switched back to the multi part assembly which came from the mirage trannies. MD722744 for the throw out bearing.
nope. you'd have to get the single assembly MR953195.
i have no idea whether or not you can just swap over the stuff from the 04+ so then you'd only have to replace the TOB down the road. there are a bunch of different part numbers for bell housings. 4 from 02-03, and 2 from 04-05.
Originally Posted by Hotshot940
hmm, interesting, well i just bought a 1997 1.8 L mirage clutch, so does this mean i would have to reuse, or buy a new throwout bearing now?
