Lancer/Mirage New Engine Build
Well have started my new engine build a few weeks ago and am almost in the completion phase of the installation. I have a Mitsubishi lancer 1998 know as a mirage in the US. I have a 1.6 SOHC 16V
parts for the build PAR con rods CP Pistons 8.5:1 Tial 38mm wastegate Tial 50mm blowoff Valve PWR barrel liquid to air intercooler ACT extreme 4puck SC 6162RE tubro 3inch down pipe RPW rear disc brake conversion Cryo treated front disc KYB AGX front and rear shocks Ground control coilovers Jun 5.1kg flywheel ARP studs Head port & polished + cc'd Adjustable cam sprocket RPW Stage 2 camshaft RPW valve springs + shims Haltech E8 + patch loom Haltech boost solenoid 3Bar map sensor Aeromotive fuel pressure regulator 255 intank pump + Bosch 044 inline -8an delivery fuel + -6an return fuel lines White line rear sway bar whiteline front strut bar KAAZ 1.5 lsd Sparco 13inch steering wheel Gauges egt, oil px, boost, water temp innovative Lc1 + xd16 gauge Precision 750cc injectors Oil/air seperator There might be some more but I can recall right now. Well here are a few pics [IMG]http://i227.photobucket.com/albums/d...nifold2016.jpg[/IMG] This is my log manifold made by a gut name Flynt from mirage forums.net [IMG]http://i227.photobucket.com/albums/d...nebuild006.jpg[/IMG] 750 cc precision injectors [IMG]http://i227.photobucket.com/albums/d...nebuild005.jpg[/IMG] RPW rear bake conversion [IMG]http://i227.photobucket.com/albums/d...nebuild002.jpg[/IMG] PAR con rods [IMG]http://i227.photobucket.com/albums/d...nebuild013.jpg[/IMG] PWR barrel intercooler [IMG]http://i227.photobucket.com/albums/d...nebuild014.jpg[/IMG] CP Pistons [IMG]http://i227.photobucket.com/albums/d...nebuild015.jpg[/IMG] [IMG]http://i227.photobucket.com/albums/d...nebuild017.jpg[/IMG] SC6162RE Turbo [IMG]http://i227.photobucket.com/albums/d...nebuild012.jpg[/IMG] Slimline fans [IMG]http://i227.photobucket.com/albums/d...nebuild007.jpg[/IMG] Autometer gauges [IMG]http://i227.photobucket.com/albums/d...nebuild065.jpg[/IMG] Ground Control coilovers [IMG]http://i227.photobucket.com/albums/d...nebuild057.jpg[/IMG] KYB AGX Shocks [IMG]http://i227.photobucket.com/albums/d...nebuild063.jpg[/IMG] Whiteline sway bar + strut bar [IMG]http://i227.photobucket.com/albums/d...nebuild063.jpg[/IMG] Expospeed slick package 13x8.5x23 [IMG][/IMG]http://i227.photobucket.com/albums/d...nebuild053.jpg 255 walbro [IMG]http://i227.photobucket.com/albums/d...NEBUILD013.jpg[/IMG] Piston and rods assembled [IMG]http://i227.photobucket.com/albums/d...NEBUILD002.jpg[/IMG] Honing job [IMG]http://i227.photobucket.com/albums/d...NEBUILD014.jpg[/IMG] Pistons installed [IMG]http://i227.photobucket.com/albums/d...NEBUILD004.jpg[/IMG] Cumbustion chamber polished and cc'd [IMG]http://i227.photobucket.com/albums/d...BUILD005-1.jpg[/IMG] Intake port & polished [IMG]http://i227.photobucket.com/albums/d...BUILD003-1.jpg[/IMG] exhuast port & polished [IMG]http://i227.photobucket.com/albums/d...EBUILD3006.jpg[/IMG] fuel lines [IMG]http://i227.photobucket.com/albums/d...EBUILD3007.jpg[/IMG] fuel lines + inline filter [IMG]http://i227.photobucket.com/albums/d...EBUILD3003.jpg[/IMG] tank with lines installed [IMG]http://i227.photobucket.com/albums/d...EBUILD3004.jpg[/IMG] Bosch 044 [IMG]http://i227.photobucket.com/albums/d...arBuild003.jpg[/IMG] shot of adjustable cam sprocket [IMG]http://i227.photobucket.com/albums/d...arBuild001.jpg[/IMG] checking turbo fitment + oil drain line [IMG]http://i227.photobucket.com/albums/d...arBuild011.jpg[/IMG] RPW patch loom harness [IMG]http://i227.photobucket.com/albums/d...nebuild036.jpg[/IMG] E8 in the car [IMG]http://i227.photobucket.com/albums/d...nebuild032.jpg[/IMG] A/F nice this is with the standard engine did some minor tuning [IMG]http://i227.photobucket.com/albums/d...nebuild040.jpg[/IMG] Gauge page again this is before i started the build [IMG]http://i227.photobucket.com/albums/d...e/DSC08142.jpg[/IMG] zero setting the cam using centerline method [IMG]http://i227.photobucket.com/albums/d...arBuild006.jpg[/IMG] PWR barrel radiator [IMG]http://i227.photobucket.com/albums/d...e/DSC08143.jpg[/IMG] ACT clutch 4puck[IMG]http://i227.photobucket.com/albums/d...ershots002.jpg[/IMG] engine installed [IMG] http://i227.photobucket.com/albums/d...atepipe002.jpg[/IMG] downpipe + wastegate pipe [IMG]http://i227.photobucket.com/albums/d...neshots001.jpg[/IMG] Almost finished |
Looking good, I can't wait to see the finished results with dyno charts ;)
so any updates on this i hope he gets back on
Subscribed
