04 ralliart radio change?
I have a 2004 ralli art but my problem isnt the radio I have a 6 cd changer that is conected to the radio idk how all that works... i need to know how i would be able to change the radio without taking out the 6 cd changer or if thats even possible....
if they're all the factory then i don't think that you can replace the head unit without some custom work.
why are you wanting to replace the radio? personally I love it. it's simple and sounds great. I added a aux input with one of those in line fm modulators that plugs directly into the antenna.
I have an Alpine CDA-117 headunit in my RA. The factory one had to go because, personally, I thought it sounded like poo and plus I have a completely different stereo in my car. Factory, it came with the "Infinity/Mitsubishi" stereo and "Infinity" 6CD changer. On the back of the stock Headunit there will be a DIN cable that runs below to the changer. As for using the 6CD changer with an aftermarket headunit, I am ~99% positive it won't work. The reason is the din cable and that it is made for our factory headunits. Also, 95% of the aftermarket headunits use iPod and MP3 cds, thus making cd changers obsolete. If you want to run the both the factory headunit and changer with an aftermarket amp then all you need is either an amp that can take high voltage connections, an in-line adapter or a processor such as the Rockford Fosgate 3.SIXTY. The in-line is the cheaper of the 3.
strife
84
Aug 26, 2020 04:17 PM
Lancermann
Dec 16, 2015 11:25 AM
RPV
12
Jul 21, 2015 08:46 PM
freeagent3117
Dec 27, 2011 06:08 PM
