Painted Valve Cover...$8!!!
Old Mar 26, 2003 | 07:25 PM
Alchemist's Avatar
**** dogg! That looks really good. Don't be afraid to bake your paint on!! That's how I got that super-hard coat on my SRI brace.
Old Mar 26, 2003 | 07:26 PM
ghostrider's Avatar
Thanks for the how-to, and way to motivate me to get mine painted.
Old Mar 26, 2003 | 08:10 PM
pinoyesv6's Avatar
here's another tip. when u use the 1200 degree paint, put on an extra layer of paint. then when u are done. take some steel wool (like 0000 grade) and some really fine sandpaper and wetsand the paint til it gets glossy. the 1200 degree paint doesn't seem to be as glossy as the 500 but the wetsanding brings out the shine
Old Mar 26, 2003 | 08:16 PM
orangebowl_jad's Avatar
very nice, thnx for the tips
Old Mar 26, 2003 | 08:34 PM
Michael's Avatar
Thumbs up
looks good!!!
Old Mar 26, 2003 | 08:43 PM
Joka's Avatar
looks nice man =]
Old Mar 26, 2003 | 08:44 PM
ghonky2003's Avatar
Looks great and the price is right. Thanks for the info. I think I'll try it tomorrow.
Old Mar 26, 2003 | 10:40 PM
lancer02Josh's Avatar
how do u bake the paint??? in your oven at home??? what is wet sanding. is that where you just sand the area but keep it wet???
Old Mar 26, 2003 | 10:49 PM
neilschelly's Avatar
You use wet-dry sandpaper, really fine grit. It will be nearby the auto paint anywhere you'd buy that, at the very least. And yes, you do sand it while wet.
-N
Old Mar 26, 2003 | 11:00 PM
Alchemist's Avatar
Josh- precisely. At least that's what I did. I used the toaster oven that I use to temper tools and set it so the thermometer inside read 300 (about 325 on the thermostat). Sprayed on primer, heat soaked 10 mins, primer, heat 30 mins, remove and let cool, yellow paint, soak 10 mins, cool a little, repeated until satisfied. There may be more precise directions on the can of paint.
For the valve cover you'll probably need to use a conventional oven. I'd turn the vent hood on just in case it starts to smell.
Oh- wire coathangers are great for taking hot things out of the oven without messing up the paint. Make sure you have a place to hang the hot item from.
Old Mar 26, 2003 | 11:07 PM
Sir Lancelot's Avatar
One of my buddies just did the same thing on his Integra's valve cover in the same color. Once the paint was dry he then took a Sharpy permanent black marker and colored in what would be our "MITSUBISHI 16 VALVE" letters on the cover. It came out so nice! You might want to try that so that you can accent it a little more!
Old Mar 26, 2003 | 11:27 PM
purecoda's Avatar
So let me get this right... 500 degree paint isn't good enough? I can't imagine your engine getting much hotter than that.
Old Mar 26, 2003 | 11:51 PM
ciaxtrinity1's Avatar
i have 500deg paint too..they didnt have 1200 in purple
Old Mar 27, 2003 | 01:04 AM
M3 STYLELAB's Avatar
i think my monitor is f-ed cuz it looks pink-ish to me
Old Mar 27, 2003 | 01:13 AM
OZevoVII's Avatar
Hahahha..Thats funny you say that, my sister told me to do the same thing!
Tomorrow im gonna take somemore pics of the engine outside in the sunlight rather than the garage for a more realistic look... Very red and shiny in real life! Im really pleased!.
