WHO's RIdin the lowest
Shortbus has an Evo 6 wing for sale, i was thinking about buying it if it matched up.
but he says that it wont use the stock holes, and the post in the middle is too short to reach the trunk??
was wondering how he got his to fit.
nope...thanks to air suspension
). the evo VI wing doesn't fit the factory holes. i did not get a stock wing with my lancer so filling holes was not an issue. and the center post rests on the trunk.
the bolt holes are located at a ****ty part on the trunk. its right on the taper just inside where the weather stripping is. hard to explain but if you look you'll know what i mean. PITA the drill the holes but it was easy for the most part.
). the evo VI wing doesn't fit the factory holes. i did not get a stock wing with my lancer so filling holes was not an issue. and the center post rests on the trunk.the bolt holes are located at a ****ty part on the trunk. its right on the taper just inside where the weather stripping is. hard to explain but if you look you'll know what i mean. PITA the drill the holes but it was easy for the most part.
car is not drivable all the way down...if i turned the wheel the fender would probably rip off....this is the LOWEST the lancer can go without modifing the control arms in the front or raising the rear top strut mount in the trunk. the rear lower control arms have brackets welded on them to lower the back 2 extra inches....thus making my ground clearence suffer at normal ride height.
but damn does it handle niceee at the lowest driveable height
so did i after i looked at it....that needs to be addressed IMMEDIATELY!!
