ride became kinda bouncy
I have 17" OZ Superleggera's on my car w/ Eibach Springs
Ive notice the back springs make a noise now and I've also noticed that my ride has become a little bit bouncy.....
Could n e one explain to me why this could be and how i would fix it
THANKS !!!!!
THANKS !!!!!
You've gone to a lot lower profile than stock, so that will create some additional feel itself. But the biggest change is you've lowered your car but haven't changed the shocks. The stock shocks aren't valved for the loss in suspension travel you now have because the car is lowered. That can cause the shock to wear out pre-maturely or even fail under hard applications.
The best thing to do is find a sport shock that's meant for a lowered car. Koni, Tein, Bilstein are all good examples. You'll have a rougher ride no matter what, but with the right shocks it will be a bit smoother and safer
Unfortunately we don't carry any shocks for the OZ.
One of the guys here have the Tein Coilovers and he told me w/ the wheel size i have I will get a really bouncy ride...and when u get coilovers i thought u also replace ur struts too..so...that doesnt make much sense to me
Well coilovers can be used on the street, but are really designed for more off road applications. Not to say you cant drive them on the street, but for an everyday driver it can be a bit stiff. A coilovers shocks and springs are made to work with together, they are designed as one component. The way they are valved and rated is tuned for optimal handling, not ride.
Just because a coilover contains shocks as well doesn't mean your spring and sport shock setup will ride like a coilover. They both serve the same basic function, but perform in quite different ways. There are more streetable, softer valved shocks out there instead of a harsher race application shock. Also, many coilovers have adjustable dampening. Maybe your friend has them on sport feel or something along those lines.
There are no sport struts made for the Lancer OZ/LS. Tokico is selling them for the ES either soon, or right now. This is why going with aftermarket lowering springs or sleeve coilovers on an OZ/LS is a mistake because the stock struts will blow in a short amount of time.
something has gotta be done about this. Is there not a way to make the ES's work w/ OZ/LS?
asu11
Aug 12, 2013 08:37 AM
i_drivecode3
Jul 31, 2013 04:01 AM
siner1ne
24
Oct 7, 2012 11:06 AM
j1a7y
23
Jun 5, 2010 10:57 AM
nhsean69
Sep 15, 2006 09:25 AM
