Suspension 101
#31
3 to 4 inches. Have you check your clearences. It sounds like you will have a whole bunch of rubbing issues. Will you be able to turn your steering wheel to full lock without the wheels hitting anything? I think you will greatly comprimise the safety of your vehicle lowering it that much. The lowest I ever went on my coilover set up on my Lancer was about two inches. Even that low I had rubbing issues and I was using 15" wheels with a little bit wider tire. (205/55-15) I hope you think about what you are going to do before you move foward with this.
#36
dropped spring setup help
Im planning on getting some H&R Sport Springs but i am also interested in what set up you guys have for your lancers i want a drop of about 1.8 all around when its settled but also without blowing the bank I'm looking to spend about 400 and this is including shocks and springs only as i read that there are no real good aftermarket struts ill just get regular struts but definately would like to get good shocks to go with the H&R Sports
#38
Like you are helping amby.
Good luck getting it under $400
I just replaced my shocks/struts with kyb struts an tein s-tech springs.
struts were $350
springs were $170
the kyb struts however didn't come with bump stops or boots so I had to buy all those, and new bushing set for rear so that cost me an extra ~$100 (I can't confirm if other struts come with or without boots/bushings)
Here is a quote from my suspension help thread:
That should be everything you need to purchase. You must reuse the mounts from the old struts.
struts were $350
springs were $170
My old strut/shocks are literally trash, there is nothing left to them and if there is anything left it is torn to shreds. I think the bushing kit is the same for both front and rear. This is what I am looking at currently...
(4x) Shocks:
(4x) Struts:
(2x) Strut bushing kit: (EDIT: ONLY NEED 2 BUSHING KITS FOR REAR STRUTS)
(2x) Front strut boots:
(2x) Rear strut boots:
The strut bushing and boots cost me an extra ~$150 dollars on top of the $350 for struts and $170 for springs
(4x) Shocks:
(4x) Struts:
#41
struts were $350
springs were $170
struts were $350
springs were $170
#42
2010 lancer gts
i want to lower my 2010 gts i just put 18" motegi mr116s on it and think it will look good lower but have alot of big speed bumps in my neighborhood what would be a good drop for looks and performance without causing scrapping
#45
Lancer oz w/ stretch
This isnt really the exact thread for this but this is my 1st post on here and im wondering if there is anyone who has some imput on this.
Im driving a 2003 lancer oz with 205/40/17 hancook tires with pos (piece of ****) rims. I want to run a 16x8.25" rim with a 205/40/16 stretch. Has this been done on any other lancers.....any help!!!
