Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Official Wheel/Tire Info Thread
Old Mar 28, 2009, 11:22 AM
  #151
azn_ghetto's Avatar
this mite sound like a dumb question and answered many times
but will stock evo x rims fit without rolling fenders, lowered and running 240
cause stock evo x is +38 offset
cause im worried about if it will rub in the rear?
cause i have prodrive GC-10 18x8.5 +35 offset and need 2 c if i have 2 roll my rear fenders 2 make them fit and dono whts the widest tire size i can go cause fronts im not 2 worried about as my evo x conversion fenders r wider
Old Apr 2, 2009, 08:46 AM
  #152
Turbotech's Avatar
Im planing to install some ENKEI RPF1 IN 18X8.5 30 offset. I tell you if that fits.
Old Apr 6, 2009, 06:42 PM
  #153
MFO Jester's Avatar
I can't find a cohesive answer in this thread...
I currently have 2 options I'm looking at:
19x8.5 +42mm offset
18x8 +40mm offset
Can someone match tire sizes to these that don't rub? I don't plan on lowering the car which is why I want to go 19" to fill the well a little more.
If the offset is too much on the 19" what is an acceptable offset for this size?
Old Apr 6, 2009, 07:29 PM
  #154
Bootx2's Avatar
Did you try the link to the calculator in one of the posts on the 4th page?
Old Apr 7, 2009, 02:18 AM
  #155
MFO Jester's Avatar
Didn't even notice it. Sorry Thanks.
Old Apr 11, 2009, 04:55 AM
  #156
gOOmba756's Avatar
Anybody experienced 19x8.5" on their gts or ralliart? I'm trying to know what tire and what offset will fit without rubbing. Thanks!
Old Apr 22, 2009, 11:54 AM
  #157
bluemalachi's Avatar
New Rims Inquiry
I am getting new rims and new tires for my Blue 2008 GTS and was looking for advice. I got myself set on Falken Torgue 5's. They are 18x7, Lug Pattern: 5x114.3, offset: 42mm and center bore 73.2mm.
http://www.falkentire.com/Wheels/Pas...els/Torque-5-2
The questions I have are:
1. Will they fit?
2. How do I make them hub centric and what is the cars actual center bore size?
3. And what size tires should I get? I'm going with the General UHP 215/45-18. Is this a good choice that will fit my rim snugly and not have any overhang or stick out beyond the lip of the rim.
Any advice is greatly appreciated as I am an auto noob. Thanks.
Old Apr 22, 2009, 02:29 PM
  #158
cRc`22's Avatar
18x7 is stock rim size.. and 215/45 is also stock tire size.. so thay will all fit fine.. and if ur taking them to a tire shop to get them installed they should be able to let u know if u need hub rings or not..
Old Apr 22, 2009, 04:09 PM
  #159
cmin_nossnah's Avatar
planning to get either
5-Zigen FN01R-C Hot Version 18x8.5 +48
18x7.5 +43
what one?
also will my 2215/45 fit?
Old May 1, 2009, 11:50 PM
  #160
wanabeEvo's Avatar
Originally Posted by timo606
So what do you people think overall of the stock 09 gts tires?
first post here!
I went through them in 11000 miles, and they had no grip
Old May 6, 2009, 05:03 AM
  #161
Danyutz's Avatar
Hey guys, my 1st post here. where I live, there are other names for the equip type, for example GTS here is the Instyle, we got 4 equip types. Ok my question is, for some aftermarket rims with these specs 18x7.5 +44, do the stock tires fit? 215/45/R18(to us, stock tires are Yokohama Advan A10). Another question, if the stock tires fit on the aftermarket specs, does the tire stretches a bit, because i want that
Thanks!
Old May 6, 2009, 05:16 AM
  #162
EngRWW33's Avatar
Stock tires will be fine.
Old May 6, 2009, 05:21 AM
  #163
Danyutz's Avatar
Thanks for being that prompt. What about the stretch, will it be available?
Old Jul 18, 2009, 01:28 PM
  #164
nikkimiao128's Avatar
thanks very helpful
Old Aug 15, 2009, 06:41 PM
  #165
allegro196's Avatar
Hi i got used set of Konig Unknown wheels 18x7,5 offset 45mm the bolt pattern is 5/114.3 with Goodyear F1 255/45-18 tires i tried them on my Lancer DE 2009 and they will fit and i can turn wheels easy there is enought space but i worried that bad things can happends when im driving,maybe i can use some wheels spacers and will be ok?
Anyone tried this size (255) of tires on any Lancer?
BTW.I didnt buy this set new and tires was free.
Sorry for bad pictures ( its was dark outside) i will take new one tommorow.
Quick Reply: Official Wheel/Tire Info Thread
