adjusting my coilovers?
Can someone give me the scoop on how to adjust my coilovers so I dont have to keep going to someone to do it. My main concern now is raising the rear..Thanks..
usually, coilovers have a threaded sleeve that can be losened up with an allen key, and rotated clock(or anticlock)wise to raise/lower the car.
But don't forget, your suspension geometry will change each and every time you change ride height !!! (i.e. camber, toe, caster will change), which requires an alignment.
Good luck
Good luck
Elevation?
Does my car need to be up on a jack or is all this done from ground? I dont think my caster camber da da has ever been adjusted. They said my allignment was fine after the install and i had someone adjust it and they didnt even charge me. They couldnt have done it either. My suspension still seems to be in allignment..
you can't do it from the ground. You need to have a wheel off to get access to the sleeve on the bottom of the springs.
If your suspension is in alignment, that's awesome. Just remember to check it if you notice any problems (like car veering left/right or steering wheel not centered, or too much inside tire wear etc....)
Steering wheel centered?
My steering wheel was off center ever since after the coilover install. But my car had no pull either way and could travel a straight line for a distance. I'm only concerned with adjusting the rear. I can access it with out raising the car. I understand how the wrenches work. I know the turn equal amount on both sides then use a tape measure to check ground to fender clearance. Should be equal. Is that it? I just want to make sure I'm not missing something common scense doesn't cover.Thanks...
Coilovers
Adjusting coilovers
Just got back from the alignment and it is all good everything is set the right front is off a bit but they said the only way they can get it perfect is if they elongate the top hole a little more but they said it is not that much to worry about it. When i adjusted the front i measured from the underneath the top strut mount down to the bottom bracket where my locking nut is. It is 14'' on both sides and thats what i went by. I am riding on the KSport coilovers with pillow ball front mounts and with the adjustable top camber plates at first the ride was rough but know im pretty impressed. This is my first time trying out coilovers car is never driven in the winter and im riding on 215/35R18 but that will be changing in the near future. Looking to go down a size in rim and a little higher on the tire size considering i live in Norther Ontario.
SpeedI2acerX
Aug 22, 2015 10:07 PM
vortico
10
Oct 11, 2012 07:59 AM
OZrallyMatty
Apr 16, 2007 10:35 PM
