Tire rub research - offset rubbing wheel rim size
*For '02/03 USDM Lancer OZ, ES, and LS ONLY (preferrably lowered)
Instructions:
Reply to this post with...
1) your rim size (HxW)
2) your rim offset
3) your tire size
4) any rubbing issues
When I see your response, I will add it to this list to compile a list of acceptable and "gray area" sizes for those trying to decide what specs to get when upgrading rims and tires. THANKS!
15x6
- 34mm
- 35mm
- 36mm
- 37mm
- 38mm
--- 195/60/15 No issues (UrbanKnight)
--- 205/55/15 No issues (BoeTurboLancer)
--- 205/50/15 No issues (IamKar33m)
- 39mm
- 40mm
- 41mm
15x6.5
- 36mm
- 37mm
- 38mm
- 39mm
- 40mm
--- 225/50/15 No issues (UrbanKnight)
- 41mm
- 42mm
- 43mm
15x7
- 38mm
- 39mm
- 40mm
- 41mm
- 42mm
- 43mm
- 44mm
- 45mm
15x7.5
- 40mm
- 41mm
- 42mm
- 43mm
- 44mm
- 45mm
- 46mm
- 47mm
15x8
- 42mm
- 43mm
- 44mm
- 45mm
- 46mm
- 47mm
- 48mm
- 49mm
16x7
- 40mm
- 39mm
- 40mm
- 41mm
- 42mm
--- 215/45/16 No issues (UrbanKnight)
- 43mm
- 44mm
- 46mm
16x7.5
- 40mm
- 41mm
- 42mm
- 43mm
- 44mm
- 45mm
- 46mm
- 47mm
16x8
- 42mm
- 43mm
- 44mm
- 45mm
- 46mm
- 47mm
- 48mm
- 49mm
17x7
- 38mm
--- 215/40/17 No issues (skiidaho1978)
--- 215/45/17 rubs (skiidaho1978)
- 39mm
- 40mm
--- 205/40/17 No issues (hbMike)
--- 205/45/17 rubs in front (TproJL)
--- 215/40/17 Rubs on sharp turns (Chimera)
- 41mm
- 42mm
--- 205/40/17 No issues (Drummerjun)
--- 205/45/17 Slight rub when wheels fully turned (itscypha)
--- 215/40/17 No Issues (Sicx13)
- 43mm
- 44mm
- 45mm
17x7.5
- 40mm
- 41mm
- 42mm
--- 215/45/17 No issues... unless you have saggy springs (Blings)
--- 225/45/17 Rubs rear inside (UrbanKnight)
- 43mm
- 44mm
- 45mm
- 46mm
- 47mm
17x8
- 42mm
- 43mm
- 44mm
- 45mm
- 46mm
- 47mm
- 48mm
- 49mm
18x7
- 38mm
- 39mm
- 40mm
- 41mm
- 42mm
- 43mm
- 44mm
- 45mm
18x7.5
- 40mm
- 41mm
- 42mm
- 43mm
- 44mm
- 45mm
--- 215/35/18 No issues (Static)
- 46mm
- 47mm
18x8
- 42mm
--- 225/40/18 Rubs inside wheel well, rear fender lip (Kensuke)
- 43mm
- 44mm
- 45mm
- 46mm
- 47mm
- 48mm
- 49mm
19x7
- 38mm
- 39mm
- 40mm
- 41mm
- 42mm
- 43mm
- 44mm
- 45mm
19x7.5
- 40mm
- 41mm
- 42mm
- 43mm
- 44mm
- 45mm
- 46mm
- 47mm
19x8
- 42mm
- 43mm
- 44mm
- 45mm
- 46mm
- 47mm
- 48mm
- 49mm
Instructions:
2) your rim offset
3) your tire size
15x6
- 34mm
- 35mm
- 36mm
- 37mm
- 38mm
- 39mm
- 40mm
- 41mm
15x6.5
- 36mm
- 37mm
- 38mm
- 39mm
- 40mm
- 41mm
- 42mm
- 43mm
15x7
- 38mm
- 39mm
- 40mm
- 41mm
- 42mm
- 43mm
- 44mm
- 45mm
15x7.5
- 40mm
- 41mm
- 42mm
- 43mm
- 44mm
- 45mm
- 46mm
- 47mm
15x8
- 42mm
- 43mm
- 44mm
- 45mm
- 46mm
- 47mm
- 48mm
- 49mm
16x7
- 40mm
- 39mm
- 40mm
- 41mm
- 42mm
- 43mm
- 44mm
- 46mm
16x7.5
- 40mm
- 41mm
- 42mm
- 43mm
- 44mm
- 45mm
- 46mm
- 47mm
16x8
- 42mm
- 43mm
- 44mm
- 45mm
- 46mm
- 47mm
- 48mm
- 49mm
17x7
- 38mm
- 39mm
- 40mm
- 41mm
- 42mm
- 43mm
- 44mm
- 45mm
17x7.5
- 40mm
- 41mm
- 42mm
- 43mm
- 44mm
- 45mm
- 46mm
- 47mm
17x8
- 42mm
- 43mm
- 44mm
- 45mm
- 46mm
- 47mm
- 48mm
- 49mm
18x7
- 38mm
- 39mm
- 40mm
- 41mm
- 42mm
- 43mm
- 44mm
- 45mm
18x7.5
- 40mm
- 41mm
- 42mm
- 43mm
- 44mm
- 45mm
- 46mm
- 47mm
18x8
- 42mm
- 43mm
- 44mm
- 45mm
- 46mm
- 47mm
- 48mm
- 49mm
19x7
- 38mm
- 39mm
- 40mm
- 41mm
- 42mm
- 43mm
- 44mm
- 45mm
19x7.5
- 40mm
- 41mm
- 42mm
- 43mm
- 44mm
- 45mm
- 46mm
- 47mm
19x8
- 42mm
- 43mm
- 44mm
- 45mm
- 46mm
- 47mm
- 48mm
- 49mm
