Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
2006 Lancer LS strut/spring suggestion
Old Mar 8, 2017, 11:22 AM
Lionelo Espina's Avatar
Question 2006 Lancer LS strut/spring suggestion
Good day,
I'm looking for info on what combination of spring and struts to put on my car, this is my day to day car, and i don't do any type of racing, just going for the look. I want to lower it a bit as i have installed 18"rims with 215 35-18 tires and want it to look better. Here a pic i took from it.
Thanks for any advice.
Lio,
Attached Thumbnails 2006 Lancer LS strut/spring suggestion-img-20170306-wa0004-1-.jpg
Old May 4, 2017, 08:26 AM
SilentCool's Avatar
Hope all is well, very clean looking lancer. Most people use a combination of *Kyb-Gr2/Excel-G* shocks & struts with *Tein S-Tech* lowering springs. Based on what you're looking for those should suit you well. I am assuming you would be changing everything out since it may not be wise just slap some lowering springs on stock shocks.
A step up from this would be the Tein Street Basis which are pretty much a shock/lowering spring combo giving you the ability to adjust to your desired ride height.
Old May 5, 2017, 06:29 AM
Thumbs up
Thanks for your reply SilentCool, what would be the main difference between throwing strut/shocks/lowering springs vs coilovers? I read somewhere that driving with coilovers are stiffer, this is my day to day ride, so as i said, i'm just going for the look rather than performance for racing...
Old May 5, 2017, 08:38 PM
SilentCool's Avatar
I get it, trust me! I was in the same boat at one point. I opted for the Tein Street Basis based on my research. I daily drive my car, looking for a mild to moderate drop and also figured that it would be best to get shocks that were at least designed to deal with lowering a car, not that the kybs are bad, many people here have used them with lowering springs and they were fine. Sure the Teins are stiffer but to be honest any aftermarket shock and spring combo would be. Some more so than others. The Street Basis set was a decent balance of comfort & performance to me.
Cost is something you should also consider, a set of kyb shocks would be around $300/$350 and lowering springs would cost you another $150/$200. The Street Basis would be around $500/$550 depending on where you shop.
Lionelo Espina (May 8, 2017)
lancer586
Jun 10, 2014 03:49 PM
tnn35
Sep 10, 2011 10:31 AM
jman85
Apr 22, 2011 09:57 PM
lucky04
Mar 9, 2005 10:30 AM
Quick Reply: 2006 Lancer LS strut/spring suggestion
