Camber 2011 Lancer ES
Hello everyone,
ive been searching but not seeing solid data for non Evo’s.
Im wanting to get some negative front camber in stock front suspension. Ideally -1.75 to -2.0
rear don’t care, got 25mm sway bar to take care of that and rear tire wear is fine. Front is very little if any negative camber.
My my thoughts are camber bolt for front, thoughts? Experience?
I thouth the ES front camber and caster is set at the factory and can not be adjusted unless you install an aftermarket part that allows for the adjustment of said items?
Jim in Tucson
Jul 11, 2010 12:43 PM
monstar 8
19
Sep 18, 2007 01:51 AM
TexasRS
10
May 15, 2005 06:13 AM
scorke
Sep 18, 2004 02:38 PM
