Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
205/60/16 to 205/55/16
Old Sep 25, 2018, 08:40 PM
remusrm's Avatar
I am considering going from the stock 16 inch size to 205/55/16 since the 60 tires are find have quite a lot of vice and make the car feel like at rolls side to side too much. Will that be ok?
Old Oct 8, 2018, 07:30 AM
gordonctrl's Avatar
it's going to lower your ride height by 0.4 inches but the width should be the same so it you are on an ES it should be fine.
https://www.discounttiredirect.com/l...ize-calculator
Old Oct 8, 2018, 12:17 PM
remusrm's Avatar
I got the SE
Old Oct 8, 2018, 01:08 PM
gordonctrl's Avatar
Check with your tire shop. you should be fine since the rim is the same and the tyre width is not changing. Although your speedo will be a few MPH off since your will have a smaller diameter tire, hence more Revolutions=offset speedo readout.
