Brake Proportioning Valve
Hi All,
I'm very new to the Lancer world, and was wondering if it was possible to change the brake proportioning valve in a 2010 Lancer SE to slightly increase the rear brake bias. I have already upgraded the brake pads and rotors. Increasing rear brake bias a bit from stock is something I have done while tuning other cars, but wasn't able to find any info for the Lancer. Any info would be appreciated. Thanks. Paul |
Originally Posted by Paul-928
(Post 8896160)
Hi All,
I'm very new to the Lancer world, and was wondering if it was possible to change the brake proportioning valve in a 2010 Lancer SE to slightly increase the rear brake bias. I have already upgraded the brake pads and rotors. Increasing rear brake bias a bit from stock is something I have done while tuning other cars, but wasn't able to find any info for the Lancer. Any info would be appreciated. Thanks. Paul Someone who is a tech let me know. you might want to study some of the Lancer Technical documents that are out there. I will see if i can find mine |
Thank you kindly.
Is there a central repository of Lancer documentation, or should I just use Google? I'm more familiar with tuning late 80s/early 90s Porsches, so the only computers to deal with are for the ignition, fuel and ABS. Everything else is pretty much simple electrical, mechanical, hydraulic or vacuum-driven. Need to catch up with the times :) |
