Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
tranny prob with turbo
Old Nov 4, 2005 | 11:52 PM
joshthegreat's Avatar
im only running 6 psi on my auto tranny, i cant even get the tranny to shift sumtimes under boost, i have to like force shift it, let go of the gas before it will shift, if i dont the rpm's will just keep climbing , anyways one have any idea?
Old Nov 6, 2005 | 07:45 AM
airlinevomitbag's Avatar
Check the fluid. It usually tells all. Is it low? Is it burnt? Is it smelly? Does it sparkle?
Old Nov 6, 2005 | 07:46 AM
AznX TL's Avatar
Originally Posted by mitsubishi site
Adaptive Shift Control
Mitsubishi's innovative Adaptive Shift Control incorporates software to adapt to most driving conditions you regularly experience. Through advanced electronic programming, Adaptive Shift Control learns your driving habits and responds accordingly by altering shift points. The result is a car that knows how you like to drive and optimizes your experience behind the wheel.
isnt that the adaptive shift thing? it shifts to what you ussually rev it to
Old Nov 6, 2005 | 08:08 AM
Mouse's Avatar
^^^ is right. i got a auto 03 oz and it does that sometimes depending on my mood from the past couple hours/days. it revs pretty high most the time for me though.
Old Nov 6, 2005 | 11:00 AM
quickie's Avatar
So your saying that annoying failure to shift when expected is actually by design?
Old Nov 6, 2005 | 02:56 PM
AznX TL's Avatar
it means hes been stepping on it for acouple days and it adapted to it, but low rpm shifts should bring it back down
Old Nov 11, 2005 | 08:08 PM
krimson_binome's Avatar
The adaptive shifting won't cause a lack of shift. It is really just a shift point map, but you can't go outside the stock maps without some form of ecu modification. If you are having trouble with a lack of shift I suspect that either airlinevomitbag is right and your fluid is low, or you put too much stress on the torque converter and it is damaged.
blood89
10
Jan 25, 2008 10:01 AM
nubi4life
Aug 15, 2007 05:54 AM
dryad001
62
Mar 2, 2007 04:45 PM
Mitsubeastin
13
May 23, 2005 10:49 PM
Severous
12
Oct 10, 2002 10:18 PM
