Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
1st gear popping out
Old Dec 15, 2006 | 01:19 PM
Dazed&Confused's Avatar
has anyone had a problem with 1st gear popping out when you engage the clutch? It doesn't do it all the time but occasionally it will and i can't figure out why it would be doing it.
Old Dec 15, 2006 | 01:22 PM
Sap12687's Avatar
Mine is sometimes "anxious" to get out of first but never slips out unless i assist it.
Edit: Then again im blind and didn't look at what kind of car we were talking about.
Old Dec 15, 2006 | 01:27 PM
electricevo's Avatar
Do you drive with your hand on the shifter a lot? Sometimes doing this will wear the shift forks down.
Smike's Avatar
Ya, like Sap (sorta) said - I do not know if ES and Evos can be compared here - but for Evos there is an engagement adjustment rod, here is the Evo how to:
http://evomoto.com/tech_info.php?tec...d321c085330739
Old Dec 15, 2006 | 01:44 PM
alot of the time i do have my hand on the shifter but that's just mostly 1st through 3rd
Old Dec 15, 2006 | 01:46 PM
i have also noticed that i doesn't do it that much when i engine break but if i just push in the clutch and brake it happens more often
Old Jan 11, 2007 | 12:50 PM
03RallyLancer's Avatar
if you arent completely stopped after you say back out of your driveway and you put it in 1st sometimes you shifter will want to pop out.
Old Jan 14, 2007 | 01:18 PM
baileysboostdoz's Avatar
dont know what to tellya mine has never done that not even with the short shifter
Old Jan 14, 2007 | 07:51 PM
JohnnyBoy427's Avatar
Mine seems anxious to jump out of first like SAP said when the RPMS are right but i never thought of it as a problem as it doesnt jump out without a little tug
Old Jan 28, 2007 | 02:22 PM
import_speedzz's Avatar
happens to me to alot.. eversince i had a stock clutch.. it did it already too.. and now i have a stage 2 act.. it still does it.. but thats when im completely stomping on the gas.. its like telling you shift now.. im not sure if its just because of torque?..
Old Jan 28, 2007 | 02:34 PM
meckert's Avatar
If it popping out under load...and it sounds like it is for some of you--you likely have worn syncros 1-2 gear. Could be the fork--but if you have been banging gears 1-2...then thats likely your issue. M
Old Feb 3, 2007 | 10:52 PM
true tho.. it is the snycros.. thats what i was told too by my mechanic.. and i do believe him... the thing is i dont baby my lancer.. i drive it hard.. ive been on my 3rd clutch already.. luckily the tranny was still alright upon inspection...
Old Feb 4, 2007 | 05:29 PM
what do you mean by banging the 1st and 2nd?
Riz5
Aug 23, 2009 07:42 AM
superflyevo
15
Sep 28, 2007 07:02 AM
クリス
Apr 2, 2007 07:35 PM
MisterMR
14
Jul 6, 2005 11:38 AM
plokivos
Jan 21, 2005 05:18 PM
