MT Vs. CVT
Hey, sorry to bring back an old thread, but i was reading through an article on howstuffworks.com and came across this statement.
"In theory, a car with a CVT should reach 60 mph (100 km/hr) 25-percent faster than the same car with the same engine and a manual transmission [ref]. That's because the CVT converts every point on the engine's operating curve to a corresponding point on its own operating curve." - source
But keep in mind that says in theory, in real world test, it seems everyone is faster with manual. Maybe theres a way we can reprogram the cvt ecu to be faster instead of for economical? Of course it has a greater chance of breaking tho.
I have already mentioned this an ECU/CVT controller is already in the works
Sorry, bit of explanation needed. Snowmobiles and some atvs use a form of cvt as well. The biggest difference being how they engage for off-the-line performance. If you could program our cvt to have an initial engagement of 3k rpm then it would drastically improve the 0-60 times. Or have some sort of load-sensing adjustment so that the cvt revs higher on hard launches...as it currently revs to roughly 2k at max off the line...makes for slow 0-30 times compared to a manual
More theory . . .
For example, suppose you accelerate from a standstill and continue to accelerate until the car approaches redline (somewhere in the ballpark of 30 MPH???).
In an MT car you will have to shift into 2nd gear. Engine RPM will drop by a rather large increment (from 6,500 RPM down to maybe 4,500???). Unfortunately, this shift from 1st gear (ratio=3.538) to 2nd gear (ratio=1.913) means a 45% reduction in torque to the wheels
Not much choice though; you can't increase RPM forever.In a CVT, in theory, once you accelerate to some point approaching redline, the car can reduce the gear ratio in very small increments. So, instead of going straight from 3.538 to 1.913, it could go from 3.538 to 3.4, 3.3, 3.2, 3.1, etc. (I'm not sure what the exact numbers are for the CVT.) Anyway, higher gear ratios mean more torque. You therefore keep more torque over a longer period of time with the CVT. In theory, this means that the CVT has the potential to be a faster car than the MT. By the way, using the paddle shifts negates this advantage by making the car use discrete shift points, like the MT.
Here's a fairly ignorant question: Does the CVT use a torque converter like a regular automatic transmission? If so, there's a loss in torque right there. If there is a torque converter, then that would be a disadvantage to the CVT.
I wish I could speak more empirically than theoretically, but I don't have access to both MT and CVT cars, nor do I have access to a test facility, timing equipment, dynamometer, etc. However, it seems that most of us agree that the MT accelerates better than the CVT. My stopwatch pretty consistently tells me low 8's to 60 in my MT. So, something is limiting the performance of the CVT: a torque converter??? crappy computer programming???
Anyway, "adding gears to" or changing the shift points of the paddle-shift mode of the CVT shouldn't do much or any good. In automatic mode the car is capable of all ratios between some minimum and maximum values. (Note that the range of gear ratios is different for the CVT than the MT, but when you factor in the final drive ratio the range of gears for the CVT and MT are about the same.)
this one is good too
http://ca.youtube.com/watch?v=7wwesYWsa88&NR=1
http://youtube.com/watch?v=4kNtFu9kbEY&feature=related
interesting vid!
as is this one
http://youtube.com/watch?v=Bb4zdcD0G-Y
interesting vid!
as is this one
WT6MA.
Those have been out for a while. They're actually listed in the video thread in the engine forum (Yeah, I know the CVT isn't engine related, but I only have one 08 video thread...
I would never hold the clutch in and coast. Everyone who does needs to learn how a transmission works. The engine needs to be turning the gears in order to supply the rest of the trans with oil to the bearings/gears. With the clutch in, the countershaft (in the oil) stops turning while the mainshaft, above the oil is still turning from the wheels....thus no oil getting onto the mainshaft resulting in premature wear/failure...
Advice....put it into neutral if you want to coast.
I agree. I am a new MT driver but I don't think its so hard to understand that even when the engine is revving at 3k for example it doesn't mean that it's using the same amount of gas as accelerating at 3k. The throttle body is not open anyway. + When the clutch is in you can control the speed using engine braking.
BUT DON'T PUT IT IN NEUTRAL. First you have no control over the car if something happens and second I think it's illegal doing so.
I haven't had a chance to practice engine braking with mine (still learning stick). So what I was told (and what I've been doing so far), is just keeping it in gear while I'm braking. When the RPM's get low enough (around 1 to 1.5 ish), that's when I put it into neutral. By that time, I'm only a couple seconds away from coming to a full stop.
but bigger, and more advanced
