Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Why does the cvt in manual mode doesnt reach redline?
Old Jul 20, 2008 | 09:17 PM
jrsimon27's Avatar
i tried to reach redline with my cvt lancer and it doesnt even get near redline it doesnt change gears until i change it but it wont go to redline?
thanks
Old Jul 21, 2008 | 05:01 PM
DoHBoY's Avatar
Its to stop you from blowing it all to hell
Its called a rev limiter, the CVTs are stopped at around 6k or 6.5k i think. its been awhile since ive brought mine up to the limit.
Old Jul 27, 2008 | 09:15 PM
jebodiah1699's Avatar
so does this mean that there is no governor, or is that another name for the rev limiter?
Old Jul 27, 2008 | 10:25 PM
MY08GSRX's Avatar
i have mine max 6300 rpm at Drive mode at the freeway today
Old Jul 28, 2008 | 12:30 AM
Bawb3's Avatar
Yeah, the rev limiter stops you at 6.3-6.5k. All it does is cut the fuel off to keep the car from revving beyond that point, just a safety measure so you don't go and blow up your engine. Even though the engine can probably handle ~7k rpm, they set up the computer that way so the engine lasts longer with the stock tuning.
Old Jul 31, 2008 | 03:20 AM
reldas's Avatar
i am in australia and i can make my lancer go to redline in any gear i want ( i got cvt). hmm lucky me although its not like i want to redline it lol
Old Jul 31, 2008 | 03:36 AM
xXEvilMRxX's Avatar
^ what?
Old Jul 31, 2008 | 05:55 AM
reldas's Avatar
sorry i was tired, itshould make sense now
Old Jul 31, 2008 | 06:35 AM
OoLancer's Avatar
on a stock car (like the lancer) there's practically no power up there so it isn't like in the traditional sense that you keep on revving and it will produce more power.
it's not that great of a powerband. . .
Old Aug 1, 2008 | 06:45 AM
eg6motion's Avatar
^^yep. power drops off anyway, no point to go higher. Also, if you are in neutral you will notice that you can only rev to about 4K. The CVT ECU has things locked down pretty hardcore to reduce wear.
Old Aug 1, 2008 | 10:30 AM
evo_soul's Avatar
I think the theory behind it is that at higher PRM under load, variable gear ratios increase heat by a higher factor. I think the hope was to restrict the RPM range to reduce heat. I think in Maylaisa I was talking to a guy who spoke of CVT overheating issues, 3 laps at ultra high RPM would cause the CVT overheat message to get tripped. I think they resolved the issue, this was a while ago.
Reving your engine is no good for the engine, really not good for if you have a turbo. lol think of all the gas that goes out the window
Old Aug 1, 2008 | 10:36 AM
OoLancer's Avatar
i guess if you had a trans cooler maybe you could push it too redline (obviously you would have to mess with the ECU)?
Old Aug 1, 2008 | 10:53 AM
evo_soul's Avatar
yes and no, transcooler helps, and beleive me it should be a must, modded or not. But heat is the only thing that can kill this tranny, heat weakens the tranny belt and other intensively used parts.
in the CVT Lancer, I think the tranny brain is as big as the engines.
Ghilversumtuner
23
Apr 11, 2019 09:28 PM
Bow87
Aug 31, 2017 09:47 AM
ultimateshoot
Feb 18, 2014 08:55 AM
EvolvedMR
Jan 1, 2009 08:27 AM
