Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Jerky ride in 2nd/3rd between 15 and 40
Old Sep 16, 2009 | 11:59 AM
prcdslnc13's Avatar
you know if you push the clutch in when your going that slow you wont jerk. Every manual does this when it drops into the low RPMs. You hit the nail on the head when you said that you feel like the car is stalling, Thats essentially whats happening except in second and third gear your car is moving fast enough that your tranny is keeping the motor turning. Thats what your feeling, your motor trying to take the night off and your tranny kickin its ***.
I could be wrong though, its happened.
Old Sep 16, 2009 | 12:06 PM
BoostWhore's Avatar
What about changing out your front engine mount? Might take away some of the initial jerk
Old Sep 16, 2009 | 02:24 PM
yitzac1990's Avatar
yeah stronger motor mounts i know decrease wheel hop, and im pretty sure it would help with the jerking that hes talking about.
Old Sep 17, 2009 | 01:51 AM
mcl5000's Avatar
Originally Posted by Solofantasy
Its all about the driving. Really, I still get jerks sometimes.
It will get better with experience.
Actually, "rev match" is pretty important. again, that comes with experience. The closer your RPM to your gear ratio, the smoother the shift will be.
I believe, here is a basic range for our 09 GTS manual.
roughly:
1st: 2500rpm @ 10mph
2nd: 2000rpm @ 20mph
3rd: 2000rpm @ 30mph
use this to estimate your rev match. when later on, you wont need to. as you drive more, it come naturally.
approx, I forgot, but I will change them after I get off work
I appreciate your input on this, but I don't think I should need to drive my lancer any differently than any of the other 15 or so manual cars i've driven. I've NEVER had this problem in any other vehicle. Also, when people drive my car who have a manual of their own, they're always shocked.
Rev matching isn't the issue. Pressure on the gas isn't the issue. Basically, the way I drive it isn't the issue. Unless, of course, all of my friends and dad (who have no issues in their cars, mind you) magically forget how to drive stick when they sit down in my driver's seat.
It honestly makes me wonder what kind of terrible cars some of you guys have driven if you think all cars do this. Maybe all Lancers do this, which would be a terrible thing, but certainly not most cars.
"you know if you push the clutch in when your going that slow you wont jerk. Every manual does this when it drops into the low RPMs. You hit the nail on the head when you said that you feel like the car is stalling, Thats essentially whats happening except in second and third gear your car is moving fast enough that your tranny is keeping the motor turning. Thats what your feeling, your motor trying to take the night off and your tranny kickin its ***."
No, really. Every manual does NOT do this in the low RPMs. If I was only having this problem in 1st gear (which I would expect...), I'd agree with you here...but the fact that happens just as often going 40 mph makes me disagree.
Old Sep 17, 2009 | 02:13 AM
poordude's Avatar
Its going to jerk a bit at low rpms, dont worrry about it though, more experieince driving it, you will naturally learn and auto adjust
Old Sep 17, 2009 | 12:41 PM
prcdslnc13's Avatar
Yea at 40 my car doesnt do that. you should probably get that checked out. I have to be going closer to 15-20 to make it hop and even then its not bad. Somethings up.
Old Jan 13, 2011 | 08:35 AM
Solofantasy's Avatar
O dang, now I know what you are talking about. My car jerks too in 2nd and sometimes 3rd. Let off gas let it run, or let off gas and press gas again it jerks.
Hmmm, it is especially bad in cold weather too.
Old Jan 17, 2011 | 07:51 AM
amrit9988's Avatar
ride the clutch a bit more between upshifts and down shifts.....although idk why youd downshift....2 times the wear.....brake pads are cheaper than a clutch
and read the manual, your supposed to shift at 3000 rpm approx....idk the exact number
Old Jan 17, 2011 | 08:30 AM
Lancer XI1's Avatar
i havent had problems with mine yet. Just different rev points than other 5 speeds. No problem after 2 days of driving, I shift at 3500 all the time.
Virtual
Oct 8, 2016 05:02 AM
Virtual
Aug 16, 2016 07:02 PM
raytrix
Driving Techniques
15
Oct 13, 2008 05:20 AM
Dr.Sound
33
Jun 9, 2007 07:05 AM
cobra
11
Oct 24, 2006 06:01 PM
