Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Help with clutch
Old Jan 13, 2012 | 10:18 PM
02_DSM's Avatar
Help with clutch
im getting ready to replace my clutch and throw out bearing what is the easiest way to pull the trans on a lift or just on the ground from the top or bottom
Old Jan 13, 2012 | 10:47 PM
03lances's Avatar
A lift would definately be best. Most of us dont have that available though. Trans has to come through the bottom. Ive found disconnecting the lower rad hose greatly eases pulling the trans as it gives you the clearance needed to clear the subframe. Pretty easy can be pulled in under 2 hours without much trouble.
Old Jan 16, 2012 | 03:15 PM
02modlanceroz's Avatar
yeah a lift would be the way to go if you have access to one. i did mine with a floor jack and i had my jack stands pretty much maxed out and it was a ***** to get it out. even more of a pain to put it back in. but you might as well install an aluminum flywheel while you're in there. that's about what you will save if you took it to a garage
Thatotherguy
Jul 31, 2014 07:59 AM
555R
22
Jun 15, 2014 08:15 AM
silentkiller
Jun 8, 2014 05:34 PM
GSX 911
Sep 23, 2013 05:43 AM
theblackbeast11
Apr 4, 2013 10:44 PM
