clutch chatter on engagement
I have an exedy stage 1 clutch with light weight flywheel from exedy one piece. The clutch has started to chatter only on engagement to 1st and reverse kinda wondering what may be causing this, I have a 06 MR with the 6 speed. No slipping good power still but doesn't seem normal. Any ideas what this may be?
if it's only when going from a stop, or when shifting up or down at very low RPM, that's pretty normal for an aftermarket clutch, and especially with a light weight flywheel...
My ACT stage 1 chatters with OEM flywheel...rev a bit higher as you engage the clutch and the chatter should be reduced. how long has the clutch been installed?
That's exactly what its doing, that makes alot of sense, since this started when the brake/ clutch fluid was low, I got new brakes that I'm putting on all 4 with new lines and some super blue brake fluid so I will be bleeding the whole thing really soon when I change the parts and fluid out. All feedback is truly welcome and thanks to all that reply!
It's not super violent and it does it more when the car is warmed up (driven for about 15+ mins), only does it in 1st gear and Reverse upon initial engagement around 1500-2000 rpm, when it chatters it seems like its slipping alot more until full engagement. On full engagement it feels fine.
Evo VIII 4o1
12
Nov 22, 2013 10:39 AM
plan:b
Oct 8, 2013 07:21 PM
DOUGLAS
Sep 26, 2011 08:27 PM
flyinmonkey101
Apr 6, 2011 12:03 PM
