Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Trouble separating gearbox
Old Feb 15, 2012 | 11:07 AM
itsjustinmeyers's Avatar
I am in the process of trying to separate my gearbox from the rest of my transmission in order to replace my input shaft bearing. I have removed all bolts from the bell housing and it still won't pry apart. Is there something i am forgetting or some trick to getting it open? I'm really stuck here and don't know what it might be... it seems like the bearing could be seized to the bell housing size causing it to not pry apart... I don't know if this could be a possibility? Any help anyone could offer would be appreciated. Thanks
Old Feb 15, 2012 | 11:13 AM
03lances's Avatar
If you have the trans sitting on the bellhousing facing up there is a service plug that will be at the rear of the trans (will be facing straight up if you have the trans sitting as I just decribed) you have to remove that plug and there will be a c clip that holds the rear of the output shaft on. You have to release the clip to release the output shaft. After that you will have to take a prybar to the pry points to separate the case its on there really good. Dont forget there are 3 bolts on the inside of the bellhousing too.
Old Feb 15, 2012 | 12:50 PM
CrAnSwIcK's Avatar
Lol, people have cracked their transmission case doing this, and by your post, it sounds like you're on the verge of doing that...you MUST unbolt the whole thing from the block and remove it, to get the bolts inside the bell housing.
Old Feb 15, 2012 | 01:25 PM
by service plug do you mean the black rubber one on the back of the tranny?
Old Feb 15, 2012 | 01:47 PM
also i'm assuming my whole shift mechanism has to come out of the gear box, can anyone tell me how to get this off without breaking it.
Old Feb 15, 2012 | 01:59 PM
03lances's Avatar
Sounds like we need info on exactly what you have pulled off and what you haven't. Yes the shift box there does need removed I assumed you had already pulled everything else off.
Old Feb 15, 2012 | 03:15 PM
03lances's Avatar
Yes. There is also a plate on the bottom of the trans you have to take off it has an idler reverse gear you have to pull out. I pulled out all the sensors as well.
Old Feb 15, 2012 | 06:12 PM
well so far I have the transmission off the car, and I have all the sensors un-plugged, i do not however have them removed. Tomorrow i will take out the black plug to access the c clip and remove the service plate to take out the reverse idler.
what sensors are necessary to completely remove from the transmission? and how do i get the shift box off of it?
Old Feb 15, 2012 | 09:39 PM
03lances's Avatar
Download senates FSM its free and its the factory service manual. Same one I paid $$$ for. It will tell you exactly what to remove and how to do it.
Old Feb 16, 2012 | 10:13 AM
i downloaded the fsm but still can't seem to find much info on how to remove the shift controk housing from the gearbox. Can someone give me some help w/ this?
Old Feb 16, 2012 | 12:23 PM
03lances's Avatar
Did you take out the bolt on the housing next to the shift housing?
Old Feb 16, 2012 | 03:38 PM
figured it out, turns out i had all the bolts removed i just wasn't pulling hard enough to pop it out in fear of breaking something
Old Mar 30, 2012 | 05:57 PM
Chris D.'s Avatar
Is this on the forum anywhere?
I searched for Senates FSM on here and on the web and came up with nothing, got a link handy?
Thanks
Old Mar 30, 2012 | 11:44 PM
03lances's Avatar
FSM = Factory Service Manual
https://www.evolutionm.net/forums/la...able-here.html
mclaren
Mar 1, 2017 04:30 AM
Cian Mcloughlin
Feb 29, 2016 01:42 PM
03lances
Lancer How Tos / Installations
12
Feb 2, 2016 09:26 PM
eddy5201314
Apr 3, 2014 03:25 AM
booboo0187
Jun 4, 2013 10:39 AM
