Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Crank won't turn by hand!?
Old Sep 13, 2017, 02:02 PM
Dylann78's Avatar
Ok so I have been baffled on this for a few weeks now and I have no idea what this problem could be.
I recently dropped my transmission to replace the slave and clutch. Made sure the clutch was aligned perfectly so I slapped the transmission back on did up a couple bolts and tried to turn the crank by hand and it won't budge!? The transmission is flush on the engine with no gap I even tried to take off the bolts to see if it's actually sitting perfect and it is.
soon as I split the transmission a bit I can turn the crank by hand. Also it almost looks like the flywheel is hitting the transfer case but that makes absolutely no sense as this was the same flywheel I was using before and it worked like a charm. I've tried re-dropping the transmission and putting it back on and same thing something is wrong I just can't figure out what it is!
Any advice would be greatly appreciated!
btw my car is a 03 lancer Oz rally.
Old Sep 13, 2017, 03:44 PM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Make sure both dowel/alignment pins for the trans are in place on the engine block.
Old Sep 13, 2017, 03:55 PM
Dylann78's Avatar
Ya they are all in place I made sure of that
Old Sep 13, 2017, 03:58 PM
Biggiesacks's Avatar
Make sure the pressure plate isnt coming into contact with the bellhousing. Had that problem on my mustang after a clutch upgrade.
Old Sep 13, 2017, 04:07 PM
Dylann78's Avatar
ya but how is that possible? I put a new clutch in it but it's the exact same one I had in it before other than that I haven't replaced anything else so it should fit? Wouldn't make sense if the pressure plate was hitting the bell housing because it all fit before I dropped the transmission?!
Old Sep 13, 2017, 05:31 PM
if its exactly the same thats probably not your issue then. Have you checked to make sure the transmission can spin freely?
Old Sep 13, 2017, 05:46 PM
Dylann78's Avatar
Yes I also checked that, the transmission spins freely. I can spin the crank by hand like less than a squarter of a spin but then it stops so it's not completely seized. Still doesn't make sense though.
Old Sep 13, 2017, 06:18 PM
clutch disk in backwards maybe?
Old Sep 13, 2017, 06:20 PM
Dylann78's Avatar
Also double checked that, it's in correctly
Old Sep 13, 2017, 06:24 PM
well ****, thats all i got man, i gotta tap outta this one lol. Good luck getting her back on the road.
Old Sep 13, 2017, 09:58 PM
4b11slayer's Avatar
Are you using a 1/2 inch ratchet? Is it in neutral? Are both wheels off ground?
Old Sep 13, 2017, 10:08 PM
Dylann78's Avatar
Yes I'm using the right size ratchet i can get it to turn a little bit but not much then it just stops! It's in neutral and both wheels are off the ground.
arshagarbon
Apr 9, 2018 09:15 AM
heyythurr
Nov 3, 2014 11:52 AM
Evo VIII 4o1
25
Sep 7, 2013 09:53 PM
_des_
Mar 8, 2012 07:56 PM
hybrids14
Mar 19, 2007 01:06 PM
Quick Reply: Crank won't turn by hand!?
