Gear ratio's
I was looking for the Gear Ratios you guys got in your manual trans... can someone who knows them post it up...allong with the speedo readings at the top of each gear...also did you guys get the F5M41 Trans or the F5M42 Trans? I'm tring to compare...thanks
-Adam |
We have the same transmission as the Mirage, but I'm not sure about gear ratios. I used to have the info, but I can no longer find it (oddly enough).
gimme a sec...
F5M42 mph @ 6000 rpm on 195/60/15 1st ... 3.583 @ 31.8 mph 2nd ... 1.947 @ 58.52 mph 3rd ... 1.379 @ 82.63 mph 4th ... 1.030 @ 110.63 mph 5th ... 0.767 @ 148.56 mph Final Drive...3.722 |
I was gonna say- just look for Rhyzin's posts in the PDA dyno thread.
Good work man {thumbup} |
I too....was searching for the gear ratios a while back, but couldn't find them :dunno:
F5M42
thanks guys...exactly what i was looking for...
-Adam i was really wanting to compare the ratio's to the Mirage 1.5 Trans since those seemed like they would be better for the 2.0...so i maybe getting one...since its exactly the same aside from the Ratios... |
Adam, you're a madman! I love it! :lol:
I've never seen the 4g15 tranny. It's the same F5M42? Oh boy, this is making things interesting. |
just for you all to see...the 1.5 trans (Manual) F5M41
F5M41 1st- 3.583 2nd-1.947 3rd-1.343 4th-0.976 5th-0.804 VS F5M42 1st- 3.583 2nd-1.947 3rd-1.379 4th-1.030 5th-0.767 so basically 1st and 2nd are oveously the same...but 3rd and 4th are longer and 5th is shorter....if you were talking MPH range...i would think that the 4G94 and G93 would get better responces from the F5M41 trans...the 4 door Mirage's with 1.8's came with the F5M41 trans while all the 2 doors got F5M42's....and i know some of the 4 doors guys have said they pull well...guess someone would have to try both to really find out for sure...hummm maybe that will be me -Adam |
Just wondering if anyone knows the top speed in gears for the '04-'06 Ralliart. I want to compare them to an '02 OZ Rally but I cant find them anywhere. I know the ratios but not the max speed at redline in each gear.
Originally Posted by lancerguy0208
(Post 8020407)
1st - 3.583 - 32 mph 2nd - 1.947 - 59 mph 3rd - 1.379 - 83 mph 4th - 1.030 - 111 mph 5th - 0.820 - 140 mph Fin - 4.04 |
Originally Posted by senate6268
(Post 8020526)
Ralliart (6000rpm on 205/50/16 tires):
(Post 8029114)
I just want to clarify for myself, you say these speeds are at 6K. The Ralliart redlines at 6500. Did you make a mistake or would the speeds at redline be higher than these?
(Post 8029114)
| All times are GMT -7. The time now is 02:50 PM. |
