Crank won't turn by hand!?
Ok so I have been baffled on this for a few weeks now and I have no idea what this problem could be.
I recently dropped my transmission to replace the slave and clutch. Made sure the clutch was aligned perfectly so I slapped the transmission back on did up a couple bolts and tried to turn the crank by hand and it won't budge!? The transmission is flush on the engine with no gap I even tried to take off the bolts to see if it's actually sitting perfect and it is. soon as I split the transmission a bit I can turn the crank by hand. Also it almost looks like the flywheel is hitting the transfer case but that makes absolutely no sense as this was the same flywheel I was using before and it worked like a charm. I've tried re-dropping the transmission and putting it back on and same thing something is wrong I just can't figure out what it is! Any advice would be greatly appreciated! btw my car is a 03 lancer Oz rally. |
Make sure both dowel/alignment pins for the trans are in place on the engine block.
(Post 11771871)
Make sure the pressure plate isnt coming into contact with the bellhousing. Had that problem on my mustang after a clutch upgrade.
(Post 11771876)
if its exactly the same thats probably not your issue then. Have you checked to make sure the transmission can spin freely?
(Post 11771894)
clutch disk in backwards maybe?
(Post 11771903)
well ****, thats all i got man, i gotta tap outta this one lol. Good luck getting her back on the road.
Are you using a 1/2 inch ratchet? Is it in neutral? Are both wheels off ground?
Originally Posted by 4b11slayer
(Post 11771933)
| All times are GMT -7. The time now is 08:15 AM. |
