wheel noise
Could also be that the tires that were on the rear are now on the front(obviously), have more tread on them. Therefore, it's possible that the front tires are making more road noise that you are not used to hearing.
You might want to check the tires, or have a tire shop look at them, sometimes a tire will do what yours are doing when a tire is going bad. Is your steering wheel vibrating or pulsating?
i got that too but only above 40+ mph...its like a higher pitched metal whooing sound...its weird coming from the back of the car...but my tires are perfect and balanced. just slight negative camber. it seems like it came out of no where like a month ago...o well...no vibration problems and my wheels havn't fallen off yet so i'm not scurred
Drew_Kaos
Jun 4, 2012 02:45 PM
