Weird idle
Old Mar 27, 2006 | 06:52 PM
ambystom01's Avatar
Weird idle
For whatever reason my car has had some weird idle issues lately. When I start up the car it does the usual thing of staying at about 2000 rpm and dropping to around 700 rpm after a few minutes. If I drive the car for like 30 min though, the idle starts to creep up. A few days ago it creeped all the way up to 2000 rpm, and I have no idea why it's doing it. All I could think of is the temperature has been fluctuating quite a bit lately with it being anywhere from -5 to 15 degrees outside. Could be a fan problem? Anybody have some insight?
Old Mar 27, 2006 | 06:57 PM
impetus19's Avatar
no insight, but my car does the exact same thing.
sometimes it even will go back and forth from 1k to 1.5k really friggin annoying when it does that. I really notice it when i do a lot of city driving.
Could it be the isc sensor going bad?
Old Mar 27, 2006 | 07:03 PM
ambystom01's Avatar
Not sure, I'm starting to suspect based on some other posts I skimmed through that it might be related to the headers. Once I get my CEL eliminator installed I'll see if it still does it.
Old Mar 27, 2006 | 07:13 PM
TY3IK's Avatar
I have the same stuff with my car thats when ur heater is on and I thing its a trotel sensor
Old Mar 27, 2006 | 08:10 PM
ambystom01's Avatar
You have an evo though.
Old Mar 27, 2006 | 11:48 PM
ThunderOZ's Avatar
Well I've noticed that also within the last few weeks, and stock performance wise...
Old Mar 28, 2006 | 10:24 AM
Green_Bandit's Avatar
Well, mine kind of does the same thing but more like every day. When I leave the car for a couple of hours and it gets a "cold" start. It idles at first 2000 then drops to 1500 then tends to rest around 1000. I believe I read it was part of the "warm up" process. I never thought anything was wrong with it. Only a couple of times I had it go from 2K to 1500 for about 3 seconds then back up to 2K for about 10 seconds then drops to 1500 for no longer then 5 seconds then "rest" at 1000.
Old Mar 28, 2006 | 03:30 PM
ambystom01's Avatar
K this idle problem is getting nuts. I left the car idling for around 15 min while I ran inside to get some things and when I returned it was idling at close to 4000 rpm. I turned it off and left it for a few minutes and when I started it up it was still idling at 4000 rpm. I decided to just get it onto the highway so it could cool off, and sure enough when I actually got on the road it went back to idling normally. Could this be a problem with my fan? I got that recall but maybe they screwed it up or something.
Old Mar 28, 2006 | 06:44 PM
ambystom01's Avatar
bump
Old Mar 28, 2006 | 07:18 PM
ThunderOZ's Avatar
Wow...mine only rev'd that high when I reset my ecu...
Old Apr 6, 2006 | 11:40 AM
Blazin_4G63T's Avatar
I think it's normal because every once in a while Ill be driving along and Ill come to a stop and the rpm will sit right around 1500-2000 after I come to a stop and then slowly drop back down to normal. I guess it's the engine design, I don't know though.
Old Apr 6, 2006 | 11:53 AM
Yeah, I disconnected the battery one time doing a battery service and the 9v battery adapter I was using ran out of juice and I started the car back up....wham! Engine shot up to 5000 rpm and quickly dropped down to 450prm and idled low and rough for a few days, it was wierd.
Old May 12, 2006 | 07:02 PM
ambystom01's Avatar
Bump cause the car is still doing this. Currently all I can think is maybe its a heat issue. It only does it after stop and go traffic. Could the fan not be working right? I had the recall done but I think maybe my fan isn't coming on and cooling the engine off. Would the idle creep up in an attempt to cool the engine off?
Old May 12, 2006 | 08:54 PM
ambystom01's Avatar
bump
Old May 12, 2006 | 09:50 PM
ThunderOZ's Avatar
bump for some help for amby
