K&N Air Filter
Old Mar 9, 2007 | 01:45 PM
Jehuty's Avatar
OH dammit, I never had the stock filter, when I got the car, it came with the "do it urself" air filter, and the MAF sensor, had some weird gunk **** over the WHOLE thing, so I'm guessing that someone tried to seal it with that ****.
Old Mar 9, 2007 | 01:46 PM
Jehuty's Avatar
what do u mean guyver?
Old Mar 9, 2007 | 01:50 PM
Guyver's Avatar
It's not worth worrying about. From what you said about your MAF sensor, you will probably need to replace it.
Jehuty's Avatar
I'll take a pic of it later on and show you guys, how much do those run for?
Old Mar 9, 2007 | 01:55 PM
crypto's Avatar
Former Vendor
Originally Posted by blaze_125
assuming the typhoon system is junk... I'd keep the filter and hook it directly on the maf.
+1
i had the exact same problem your having. My power steering even died at one point.
just keep messing with stuff check ALL connections. I found out that the cable going from the MAF had a loose connection so i just unplugged it, blew on it to get all the dirt out, then plugged it back in as hard as i could.
Unplugged the battery for 10mins, then started it up, let it sit for 10 mins. It worked fine.. I haven't had any problems since
Old Mar 9, 2007 | 01:59 PM
Jehuty's Avatar
Hmmm......but there are only TWO connections, from the piping itself, and the MAF sensor, what else can I possibly check?
Old Mar 9, 2007 | 02:58 PM
Danny23's Avatar
You can clean out the maf sensor with maf cleaner,thats the first thing i would do after getting rid of the typhoon tube. Check all connections,and you can run the filter directly to the maf sensor. I believe you would need an adapter for it like the evo but i,m not sure.
Old Mar 10, 2007 | 07:42 PM
Jehuty's Avatar
Well, the problem has been figured out, I wanna thank snapdragun for his help, it is indeed my MAF sensor, MANY honeycombs are horribly bent, luckily I have one on the way :-)
Old Mar 12, 2007 | 12:18 PM
drucea's Avatar
And to the people talking **** about the typhoon intake, how do you come to this conclusion? I've had mine on for about 2 years now with no problems what so ever, and know plenty of people with them. And it looks a hell of a lot better than the stock rubber intake tube.
hutch959
Dec 15, 2016 06:04 PM
hutch959
Sep 27, 2016 05:39 PM
BANKS
17
Apr 27, 2006 02:44 PM
Mooshu1221
Jan 24, 2006 05:21 PM
WindsorLancer
Canadian Forum
Sep 29, 2003 11:59 AM
