Car idels high...
Old Jul 15, 2003 | 12:13 PM
Chameleon's Avatar
Car idels high...
Once I first start up my car, my car sits ideling at about 2 and a lil over 2. Its been doin this for just about as long as I can remember so I thought it was normal...but my boyfriend says thats too high for it to always be idelin...is this somethin thats normal or is somethin goin haywire?
Old Jul 15, 2003 | 12:15 PM
bobaab's Avatar
well when u first start your car it should idle high, especially if the A/C is on.
it's a problem if u see it idleing at 2k once u start driving and when the temperature is at normal operating temperature. when u stop at a light or something, put it in neutral and see if it still idles that fast..then u got a problem, if not it should be perfectly fine
Old Jul 15, 2003 | 12:30 PM
uranium9v's Avatar
mine does the same thing...races to 2.5k, then when I shift outta park it chills out.
Old Jul 15, 2003 | 12:37 PM
TurboZ's Avatar
the idle is high upon start up to allow more gas since teh air is cold. this should drop after about two minutes..if it does not try to adjust the idle down. rule of thumb is 500 rpm in nuetral of a standard and 700(in drive) for an automatic. please refer to your owners manual for proper adjustment procedures as all cars are different.
ex may have to unplug IAC motor or TPS sensor to get base idle and adjust that.
hope this helps
Old Jul 15, 2003 | 09:01 PM
1/3Evo's Avatar
Its normal for the engine to idle high on initial startup because the engine is cold and the high idle helps warm up the engine. Once the engine warms up it should settle to a normal idle. When the engine is warm it is not normal to idle at ~2000rpm.
Old Jul 16, 2003 | 01:37 AM
ghostrider's Avatar
No problems with that idle. I just got in my car at 2 am after it sat in the parking lot for hours, and it idles up around 2k. Give it a few minutes and it'll drop down to 1.5k or so.
Old Jul 16, 2003 | 10:11 PM
KTRLancer02's Avatar
yeah mine does the same. It goes up real high and then goes back down after warming up.
cesare77
Jun 15, 2010 01:55 AM
evokid511
Mar 26, 2009 08:45 AM
AutobonEvo
43
Jul 8, 2007 03:55 PM
dj0521
Mar 7, 2006 06:01 PM
raywong
13
Oct 4, 2003 10:25 AM
