Must fix annoying rattle!!!!
Old Nov 22, 2007 | 06:51 PM
Walkingchaos's Avatar
ok guys im hoping someone had had this and fixed it before and can tell me how. Ive got a solid sounding rattle coming from what sounds to be the rear passenger quarter of my cabin. I cant find the damn thing. Ive pulled the trunk all apart gotten in there and cant find anything loose . . . ? Anyone had this issue as well ?
Old Nov 22, 2007 | 09:27 PM
atilla's Avatar
probably the rear deck and/or the seatbelt assembly... buckle the seatbelts in the back of the car and see if it helps. i had a mean rattle from the rear deck but i forgot what fixed it considering how many different fixes i tried.
Old Nov 22, 2007 | 10:41 PM
SLVROZ_03's Avatar
Yeah, I've got a rear-deck rattle too...but the 2 12s don't help! LOL
Old Nov 22, 2007 | 11:14 PM
J Money's Avatar
ha ditto...lancers are the worse on rattling...and when i say the worse...i mean TERRIBLE..
Old Nov 23, 2007 | 06:57 AM
atilla's Avatar
i cut down to a single 12 in the trunk which isn't rattle-the-crap-out-of-your-body-loud, but it's enough bass for me. i barely have my radio on anyway... i prefer the 4 cylinder symphony under the hood, haha.
Old Nov 23, 2007 | 07:55 AM
has anyone pulled the rear deck apart enough to find it ? Ill try the seatbelt trick thanks
Old Nov 23, 2007 | 09:32 AM
atilla's Avatar
i tried pulling it out one day but i couldn't figure out how to get the damn thing out.
Old Nov 23, 2007 | 09:37 AM
crypto's Avatar
Former Vendor
i got a rattle since i put my Evo wing on. I figure its cos the trunk doesn't have the middle support anymore
Old Nov 24, 2007 | 09:06 PM
seat belt trick didnt work. anyone got anything else ?
Old Nov 29, 2007 | 07:03 AM
blaze_125's Avatar
I beg to differ. Come for a spin in my Delsol, or any Delsol that is and you'll find the Lancer is pretty quiet
Chaos, your rattle could be a bunch of stuff. It could be your trunk liner, it could be a plastic trim, it could even be a penny stuck under the seat. My advise to you, take the trunk liner and plastic trim out(the trim that is right behind the seat and goes around the hole in the trunk "wall").
If taking all of that out doesn't solve you rattle, it will at least help you pinpoint the source of the sound as it will eliminate a bunch of possibilities. Also look in the spare well. Make sure everything is tighten properly down there.
Old Nov 29, 2007 | 12:39 PM
SLVROZ_03's Avatar
The only Del Sol I rode in is my friends 11psi stock block T3/T4 setup & the only thing I can hear is the open DP, turbo spoolin, and the BOV! Brings a smile to my face every time!
Old Nov 29, 2007 | 12:44 PM
Tsurugi-san's Avatar
If the rear deck of your lancer is identical to the Evo, then there's a thin layer of something like aluminum plate under the covering, and wherever it comes in contact with the actual deck, you'll have a rattle.
The way I fixed it was to remove the rear speaker grills, and start inserting thin foam inserts under the material --- you'll see what I'm talking about. If you use enough foam you'll have a quiet deck. This was my way of recycling all of my using Meguiar's applicator pads! They worked great for this.
Get to it!
jnut24
Mar 12, 2016 03:39 PM
jnut24
Northwest Region
15
Sep 25, 2011 10:00 AM
damstr
Oct 31, 2007 08:38 PM
avengerhed
Dec 14, 2005 07:58 AM
escoson
Dec 24, 2004 04:48 PM
