P0135 CEL 2002 Mitsubishi Lancer ES
Old Jun 15, 2009 | 03:41 PM
darkmitsu's Avatar
I got a P0135 CEL...
1.changed the oil
2. changed the spark plugs...
After about 2 hours of driving it and 4 ignition on/offs the CEL went away... Just thought I would share... we will see if it stays gone --- next step would be the o2 sensor...
Old Jun 16, 2009 | 11:54 AM
03lances's Avatar
Good to know Did you notice an mileage difference b4 the light cam on?
Old Jun 16, 2009 | 08:37 PM
darkmitsu's Avatar
yes I did notice a mileage difference, I usually get around 430 miles to a tank, but it was only seeming to get about 390-400 a tank during the previous week leading up to the CEL ... ran a few more tanks thru it since the light and the mileage is up and down , im guessing the front o2 sensor is probably bad or going bad... although the stuff I did got rid of the CEL I guess its just enough to hide the problem...
Old Jun 19, 2009 | 09:26 AM
Jehuty's Avatar
what the hell...I drive about 34 miles to work, and I have to fill every 4 days. straight driving barely any stop and go.
68 x 4 = 272 MPG...why?!?!
Old Jul 5, 2009 | 09:34 PM
darkmitsu's Avatar
update, I just got another tractrix cable and the dtc is still there its not enough to trip the cel but its is still there. you can clear it with the tactrix cable but it comes right back up as a dtc.
Old Jul 5, 2009 | 09:47 PM
03lances's Avatar
So it has the pending code still, the new plugs are probably keeping everything close enough to keep the CEL at bay, sounds like 02 to me...
Old Jul 5, 2009 | 10:06 PM
LancerEVA06's Avatar
The O2 Sensor heater is most likely bad. If it was cold out (ie <45°) you'd probably set the MIL=on within 15 minutes of starting the car. Check the heater circuit resistance when the car is cold... if memory serves me correct it should be between 4-7 ohms.
stunt2
Mar 9, 2011 07:44 AM
rastaj0ker
Lancer Troubleshooting
Oct 26, 2009 08:13 PM
honki24
Sep 28, 2009 07:11 AM
BJai02
May 27, 2007 02:39 PM
mostro
Jan 27, 2007 03:55 PM
