ddm tuning hid kit
Old Aug 28, 2009 | 04:05 PM
camillejorge8's Avatar
ddm tuning hid kit
I just bought a 55w 8000k from ddm tuning. My problem is When my car is moving already the headlight won't turn on and even if i park my car it won't turn on. then what i did is turn off the engine of my car and take out the keys in it. then turn on again my car. then the headlight works! i dont know what should i do. anybody help me please? thanks so much.
Old Aug 28, 2009 | 04:13 PM
Greedy_son's Avatar
Does your headlight turn on when you first start your car?
If you dont have a relay then thats why they arent turning on. The HID ballasts need a constant voltage. If you dont turn your headlights on all the way before you put it into gear then your DRLs (day time running lights) are kicking in. Your DRLs require less voltage then HIDs and the ballasts are switching of to protect your bulbs from damage.
Either turn your lights on all the way before you put it into gear or get the relay harness and this will solve your problem.
Use the search button as well because this is a common topic.
Old Aug 28, 2009 | 05:04 PM
My headlight is not turned on before I start my car. I start my car then turn on the headlight.
But when I put it in gear first before turning on the headlight maann it won't work.
Old Aug 28, 2009 | 05:16 PM
Greedy_son's Avatar
Its the DRLs man lol. They cut in when you start driving or put it into gear.
Turn on your car, turn your lights all the way (two clicks) then put it into gear. If you switch them off while driving the only way to turn them back on is switching off your car.
Get a relay harness from DDM. Mine are from DDM and do the same thing.
Old Aug 28, 2009 | 05:25 PM
oh sheez bro you are right. the only way to turn it back on is to turn off the car! you're a genious bro! thanks very much! that helps alot!
Old Aug 28, 2009 | 05:30 PM
EvolNinja's Avatar
Did you upgrade the fuse from 10AMP to 20AMP?
Old Aug 28, 2009 | 05:34 PM
nope. nothing like that. I just perfectly installed the hid kit. thats it
Old Aug 28, 2009 | 05:40 PM
EvolNinja's Avatar
Are you replacing the low beam or high beam? I think it's the same as when I did mine. I had to replace the fuse to the low beam from 10 to 20 amps. GL! By the way, how much did you buy your kit for?
Old Aug 28, 2009 | 07:58 PM
Greedy_son's Avatar
^ only really need low beams with HIDs, Did you upgrade the fuse on an 08 or 09? DDM has digital ballast that cut out when the voltage dips from DRL's.
http://www.ddmtuning.com/index.php?p...=101&parent=60
$65 for the digital 55W slim ballast. had these for 1.5 years and still running great.
Old Aug 28, 2009 | 08:01 PM
i didn't upgrade the fuse. i have an 09 gts. do you think I need to?
Old Aug 28, 2009 | 10:34 PM
Greedy_son's Avatar
No, never head of this. HIDs draw less power from the car so it will never blow the fuse. The ballasts do all the work by bumping up the wattage.
Old Aug 29, 2009 | 10:44 AM
jRox's Avatar
Check out my sig. It will get resolve your issue.
Old Jan 24, 2011 | 06:19 AM
quickflips's Avatar
for those who got ddmtuning kits, what else did you guys buy from them when initially purchasing? harness, eliminator, adapter, brackets?? if i got the harness or eliminator do i still need the drl bypass? i remember reading somewhere that the eliminator helps with any flickering issues idk??
Old Jan 25, 2011 | 08:05 PM
quickflips's Avatar
anybody??? i want to order mine soon :/
Old Jan 27, 2011 | 08:20 AM
Philly101's Avatar
Xenonsupply has really good HIDS. It comes with a harness and a capacitor so your DRL don't flicker. So there is no issue with DRL.
