high rpm, no power
Old Nov 17, 2009 | 10:25 AM
batmanlee's Avatar
high rpm, no power
I have been driving my manual 2003 Lancer OZ for 150,000 miles now and it is finally starting to give me problems. besides electronics, never been modified, never been raced.
I notice now that whenever I step on the gas, in whatever gear and whatever speed I am in, the RPM shoots up extremely fast. It takes a while but then comes back down to normal. When the RPM shoots up there is absolutly no power as you might of expected.
I notice it is also very difficult now to even put my stick into first and second, and feels as if the gears are not "catching" and responding like they use to.
I am accelerating at a crawl, especailly in the highway. I can still reach higher speeds but takes me a long time.
I recently had an oil, tranny fluid, air filter, plugs + wire change. Any suggestions? Is this a tranny problem or a fuel problem?
Old Nov 17, 2009 | 10:31 AM
Jehuty's Avatar
it's a lancer problem...it's your engine, your car is slow.
Welcome to owning your lancer.
Old Nov 17, 2009 | 10:32 AM
Jehuty's Avatar
In all seriousnes, we need to know if there are any strange noises or anything like that so that we can let you know.
Old Nov 17, 2009 | 10:33 AM
High_PSI's Avatar
+1, very slow car, but to be perfectly honest it is your clutch. It is slipping. 150K is a very long time on a stock clutch so congrats.
That is all, purchase a new clutch, go heavy duty if you want and install a LSD (Limited Slip Differential) It'll help with launching your car a bit more as it'll give power to both front wheels instead of just one.
Old Nov 17, 2009 | 05:30 PM
batmanlee's Avatar
Thanks guys, I checked out the signs for clutch slippage and looks like thats my problem.
I put it at a complete stop and try driving off in fourth gear and it let me without stalling. It would of never done that when I first got it (not that I really tried).
Old Nov 17, 2009 | 05:34 PM
buchnerj's Avatar
Yeah, the clutch for sure. Being able to pull out in a high gear is the first sign, also you can try and go up a hill in a higher gear and the RPMs will shoot up but not speed. Same thing. Go clutch shopping..... or new car shopping..... just kidding. Good luck
Old Dec 24, 2009 | 06:24 AM
oznoobfabber's Avatar
where can we get a lsd for our car
Old Dec 24, 2009 | 07:12 AM
senate6268's Avatar
RRM, RPW, Cusco
Old Dec 24, 2009 | 12:27 PM
High_PSI's Avatar
I think the Raliart had one, the older 2.4 SOHC unit. If not get the cheapo Phantom Grip units as you don't make enough power to over run the unit.
http://store.phantomgrip.com/catalog...73d223611acab4
Jakdup36
10
Dec 14, 2016 03:44 PM
EVILutionVIII
Aug 12, 2007 11:38 AM
Chris@nolimitmotors
Mar 31, 2005 02:37 PM
Chris@nolimitmotors
Mar 24, 2005 02:47 PM
Alchemist
Lancer Tranny/Drivetrain Tech
13
Jan 22, 2004 09:18 AM
