incorrect temp reading
Old Jan 23, 2015 | 05:42 PM
marcusgold's Avatar
after searching and finding some info i decided to post.
so what im dealing with is a temp gauge that jumps past hot when the car is running.
for ****s and giggles i replaced the t stat and sender still the same upon start up jumps and stays above hot. the temp is sitting at 194(thanks solus)
i also ran a new wire from sensor to the harness in the cabin and nothing changed
also on a side note dome light gas gauge and temp gauge work when they want..
i have checked all the grounds i could find
Old Feb 24, 2015 | 08:12 PM
marcusgold's Avatar
woohoo now my speedo reads incorrectly...
i leaning towards a bad cluster
Old Feb 24, 2015 | 09:20 PM
jakermeister's Avatar
Sounds like it. You can use a variety of other clusters tho including a evo 8 cluster to replace it with. You'll need to get your current mileage switched over to the new cluster. The dealership can do this but I'm not sure what they charge. Might want to look your fuses over first.
Old Feb 25, 2015 | 10:00 AM
marcusgold's Avatar
I have checked all the fuses everything is good...now I just Ned to find a cluster cheap just in case it doesn't fix the issue I won't be out of alot of money
Old Aug 6, 2016 | 10:51 AM
marcusgold's Avatar
ok so i bought a evo cluster and guess what everything works....it was a bad cluster
its been so long since ive had correct readings
shangai
Nov 5, 2013 08:33 PM
WW13X
Feb 13, 2013 02:56 AM
import111
Mar 10, 2012 06:52 AM
BillyBobJoe
Jan 12, 2009 03:16 PM
destro92179
Sep 9, 2008 08:03 PM
