Input and output speed sensor location
Old Apr 8, 2017, 05:12 AM
Dstorm7's Avatar
Hi all,
Does anyone know where the input and output speed sensors are located on a transmission of a 2009 lancer DE?
How do you reach them, do you have to remove a lot of part?
Thx in advance
Old Apr 20, 2017, 04:06 PM
Dstorm7's Avatar
Never mind, found them and replaced them.
Car accelerates a whole lot better.
input speed sensor was on the frits and decided to replace the both input and output
Old Mar 6, 2018, 12:19 PM
ChristPuncher's Avatar
And?
Well...where were they? it would really help me out of a Jam, lol.
Old Mar 12, 2018, 09:37 AM
Dstorm7's Avatar
I found them as follow:
I removed the battery and the Air Cleaner Body .
If not mistaken the input speed sensor is located on the transmission in the direction of left of the wheel, you will see a connector sticking out and the output speed sensor is almost in the neighborhood of where the Air cleaner body is on the transmission ( you have to feel around for the connector)
I may have said the order of sensor wrong, but if you have the replacement you can compare their shape so you know which is which.
Old Mar 12, 2018, 10:36 AM
Nifty. You have to replace yours due to hesitation during acceleration? It's the problem I'm having, and the mechanic is stumped.
Old Mar 12, 2018, 11:01 AM
Dstorm7's Avatar
Yes, my car would sometimes not accelerate, I had to some press the gas pedal few seconds apart for it to accelerate.
I got a quick scan that said my input speed sensor was not working, because my check engine was on, but I don't recall if I had another issue
The mechanic told me that the input sensor had issue, but the out put is working fine.
I decided to replace both them, so I could be done with it.
Now she's accelerating perfectly without issues.
Does your mechanic have a scan tool that can read transmission issue?
Old Mar 12, 2018, 11:22 AM
Yes, we both do. Mine just shows an error in module $07e8 and $07e9 which indicates engine and transmission, but my check engine light is not on, so it won't go further Into detail than that. It's my girlfriend's car, a 2009 GTS with the 2.4, and at the beginning of the winter, the tire shop she went to put the wrong sized tires on the front. (her winters are 205/65/16r and they had screwed up and put 205/60's on, but just the front. Pretty sure that's what's causing this mess without the sensors themselves being pooched. Were 3 weeks away from getting our all seasons back on now though, so I guess we will have to wait until then *grabs at hair*. I'm not naming the tire company, because you'll probably see us in the paper soon and I don't want it to seem "pre-meditated" Gf has been t-boned at a yellow due to this.
mattu
Lancer Tranny/Drivetrain Tech
Sep 1, 2015 07:14 PM
Thahomeboyb
Lancer Troubleshooting
Nov 15, 2014 06:54 PM
#1deliveryboy
Oct 19, 2006 09:56 AM
WRC VII
21
Jan 2, 2004 06:05 AM
Quick Reply: Input and output speed sensor location
