09 Lancer ES Ignition switch locking up.
Old Sep 27, 2017, 08:21 PM
ZMitsu's Avatar
Hi there new to the forum here. I have 09 Lancer ES. My ignition lock started having problems unlocking. At first it was intermittent. then it just got worse. I bought the kit from the dealer that has the ignition lock, door lock, and two key/remotes. My mechanic installed the locks, and swapped the internal parts of the remotes from the old to the new. It worked fine for a week, and then the same problems with the ignition lock again. Only this time it took about a few dozen times to get the unlock the ignition. Any suggestions would be appreciated. Thanks!
Old Sep 28, 2017, 11:23 AM
Veronica's Avatar
Does a twist of the steering wheel (left or right) work to free it?
Old Sep 28, 2017, 05:58 PM
ZMitsu's Avatar
Unhappy
I did try that, but no it did not work.
Old Sep 29, 2017, 07:02 AM
ZMitsu's Avatar
One other idea I had does the battery in the remote make a differnce? I can still lock and unklock the doors, bur wasn't sure if there was a chip in the remote that makes the ignition unlock. This is the remote with the key built into it.
Old Sep 30, 2017, 12:26 PM
ZMitsu's Avatar
So my Lancer sat for a few days. Today I was able to unlock the ignition and start on the 1st try. I took it for a drive, and so far the next 3 starts it has unlock at the first try as well. Previously I did use this liquid graphite on the lock and key. Not sure if that helps or not.
Old Oct 1, 2017, 10:17 PM
ZMitsu's Avatar
My mechanic took the ignition lock out. Figures it did not act up at that time. Hes doing some more research on my Lancer. He think's it's possible it could be the following 2 parts. In 1 picture the cylinder lock mount. The 2nd picture (forgot what the part is called), it bolts to the top of the steering column. The red arrow in the picture points to the part. I'll have to find out the cost, and also wait to hear back from my mechanic.
Cylinder Lock housing.
Part on top of column mount.
Attached Thumbnails 09 Lancer ES Ignition switch locking up.-cylinder-lock.jpg   09 Lancer ES Ignition switch locking up.-column-mount.jpg
N33d4sp33d
Jul 20, 2012 03:06 PM
01 Trans-Am WS6
Jun 8, 2011 02:21 PM
Eugene@SPE
Evo 'For Sale' Exterior Styling
Apr 20, 2010 11:31 PM
rodent
Jan 20, 2010 07:31 AM
mmartahus
10
Dec 22, 2008 03:06 PM
Quick Reply: 09 Lancer ES Ignition switch locking up.
