2003 OZ Rally burning up coil packs
Old May 25, 2018, 09:29 AM
Eleventy5's Avatar
Started it up the other day, to move it out of the driveway and she was running really rough. I popped the hood to check for vermin, or maybe an untied shoe lace that I might be able to fix, and the number 1 coil pack popped like a firecracker and white smoke started oozing out. So I killed the engine, let the coil pack cool down and pulled it off. The plug well had about half an inch of oil in it... Assuming I had found my problem I bought a valve cover gasket kit with plug seals, 2 new coil packs and 4 new NGK plugs. everything plugged back in and started her up. within a minute the new coil pack popped and smoked as well. I am at a loss. I can't see anywhere where the wiring harness has any damage (rodents are a thing out here) and it was running fine last week. Any ideas on what could be causing the coil packs to pop and burn?
Old May 28, 2018, 10:37 PM
OZR_Lancer's Avatar
check plugs themselves ? did u drain/remove oil from tubes ?, did you check that you did install plug wires in right oorder ? had to ask
Old May 29, 2018, 03:47 PM
Eleventy5's Avatar
Replaced the plugs, removed the oil from the tubes before pulling the plugs, absolutely installed plug wires in the correct order also. And considering the original coil pack popped and smoked before I did any additional work, I am thinking it is not related to anything I have done. Thanks for the reply!
Rossi_24
May 21, 2016 09:09 AM
Raceghost
21
Nov 2, 2012 07:47 AM
ozracer4
Lancer Aftermarket Forced Induction Tech
Jul 26, 2004 05:16 PM
gb-motorsports
Nov 3, 2003 11:38 AM
rhyzin
Lancer Troubleshooting
Jun 25, 2003 03:33 AM
Quick Reply: 2003 OZ Rally burning up coil packs
